L filter or light pollution filter?
ZWO ASI1600MM/QHY163M 8 replies361 views
georgian82 avatar
Hi guys,
I see a lot of guys out there imaging with a light pollution filter in place of the L filter. I live in an orange zone…should I consider doing that? woukd I have to expose longer with the light pollution filter compared to the L filter?
I don't have the ASI1600MM yet as I am still saving my pennies but I am learning as much as I can in the meantime since I know I will acquire it by the end of the year (that's my hope).
thank you all!
Sebastian
John E. avatar
Hi Sebastian, I live in a White Zone and imaging with an L filter is difficult. My clubs site is orange/green and an L filter works better there. I also have a 2" LPS D1 filter that I used exclusively with my DSLR. I do want to try with my ASI1600mm-c but need to adapt for it. But for me, the best move was to move to NB as doing LRGB from my home site has too many problems. As far as exposure, the LP filter ALLOWED me to expose longer as it gave me better data. A very knowledgeable imager mentioned that I should definitely use the LP filter in our orange/green zone for everything but galaxies.
georgian82 avatar
John E.:
Hi John,
Thank you very much for your input! I appreciate it.
Cheers
sebastian
Well written Respectful
Edward Overstreet avatar
Depending on what OTA I am using but I either have a LP filter screwed on the Coma Corrector (Newt) or field flattner/reducer refractor and SCT.   So all filters, LRGB are shooting through the LP filter.  This may be all wrong - but what I am doing regardless - I live in an orange zone.  I do take the LP filter off when using NB.
georgian82 avatar
Very interesting @Edward O. I didn't think it was possible to use the LP in front of all LRGB filters. Thank you for your input!
Cheers
I would recommend that you take an adequate number of flats to deal with any vignetting that may happen because of the distance between the LP filter and LRGB filters.   Personally, I cannot tell a difference in the vignette, with our without the LP filter but others have mentioned it and it may affect your setup.
However, placing the LP filter in front of LRGB filters should be no different than putting one on an OSC.
bobzeq25 avatar
Are you doing gradient reduction in processing?  If not, that's the first step, the LP filter the second.  Going from one shot color to RGB or LRGB also helps.
The stronger the LP filter, the more you have to increase exposure, the more it distorts the color balance, which then needs to be fixed.
Concise
I use Dynamic Crop - for all LRGB - HaOIIISII so they will be identical - I can't think of any time in the as 3 years (when I started attempting this challenging hobby) that I didn't have to crop.   Also, using PixInsight for most of the heavy lifting then PSCC for the rest.
Once all images are identically cropped - I then use Dynamic Background Extractor.   This does a great job of removing all unwanted gradients….I use the Automatic version on clusters and most galaxies…..and the manual version if there is a lot of nebulosity regardless of the target.
Chris Sullivan avatar
I live in a white zone near John. I've been using a Baader Neodymium (Moon & Skyglow) filter for luminance in my last couple of galaxy images. I think it helped a lot. The spectrum between the L and Neodymium filter isn't all that different - they both cut off at the same point, but there are 2 or 3 gaps in the middle. My main problem with it is that it isn't parfocal with my other filters. I had been using a 2" Orion Skyglow Astrophotography filter in front of my coma corrector, but I believe it caused some weird reflections in some of my images. Right now, I plan on continuing to use the Skyglow filter in my OSC, but not for monochrome.
Baader RGB Filters and LP
Hi all, I'm considering to buy a mono cmos camera with narrowband filters and RGB filters. I live in Venice (Italy) and the light pollution is medium. I'm considering Baader set of RGB filters. Baader declares, about their filters, that "...
Discusses light pollution filters and RGB filters for mono camera imaging.
Oct 2, 2017
Light pollution filters: suggestions?
Hi all, I recently started guiding and as a consquence of the prolonged exposure (300s) - this is my guess - all of my pictures have a very annoying red tinge due to light pollution that wasn't present in my previous unguided images (60-90s). I t...
Addresses light pollution filter usage and exposure time considerations.
Feb 23, 2019
Light pollution filter - which way is better?
Hello to anyone who would have an opinion.. I am wanting to buy an Astronomik light pollution filter for use with a CCD refractor and CCD SCT LRGB setup. Should I get one to replace my L filter when shooting or should I get one to go forward of the f...
Compares light pollution filter options for LRGB imaging setups.
Apr 10, 2018
