I'd first make sure that the red tinge isn't amp glow - on my Nikon, the amp glow would always show up as a red cast. Light pollution would show up as bright pink, but then again, I image under Bortle 7-8 skies. For my color cameras, the Orion SkyGlow Astrophotography filter did a great job. There are other good options out there, like the Optolong L-Pro, Astronomik CLS, Astronomik CLS CCD, IDAS LPS P2, Baader Moon & Skyglow Neodymium, etc. Some are known for causing a bit of a bluer cast and false color than others and some are better at filtering out light pollution where others can be a bit weak. I'd take a close look at what spectra they block and read reviews. They're all very helpful - even under skies that aren't that light polluted. Jerry Lodriguss has some great examples of how they work on his site:
http://www.astropix.com/html/i_astrop/cls_filter.htmlIf you have severe light pollution (Bortle 7 and higher), I'd recommend switching to mono if you can. I found it much easier to manage light pollution with a mono camera than a color camera. Good luck and clear skies!
