Light pollution filter - which way is better?
13 replies466 views
Charles Harris avatar
Hello to anyone who would have an opinion..
I am wanting to buy an Astronomik light pollution filter for use with a CCD refractor and CCD SCT LRGB setup.  Should I get one to replace my L filter when shooting or should I get one to go forward of the filter wheel somewhere?  I am leaning toward getting one to go in front of the filter wheel in the optic train somewhere..
thx
Charles
John avatar
i use a Lumicon UHc..its  very good.  with heavy polution..narrowband filters will work better
Sara Wager avatar
I use a Chroma LP filter as my luminance in one of the rigs and the other uses a HUTEC IDAS, again as the luminance filter only. I thought long and hard about this and if I'd put the LP filter in the front of the imaging train then it may have had an adverse effect on my Narrown band data collection. I'm happy how it works  smile
Hello Ms. Wager,
…I love your artistic interpretations of the heavens..I was quite surprised to get to chat with you for a moment in time.. thanks for the guidance.  I will consider it gospel.
Charles
Respectful Supportive
John:
Hello John,
I see the difference in some of the same shots you have taken that I have taken.  My pollution is not bad, but I think it is probably borderline.  I guess I am probably considering getting a substitute for the Lum filter at this point unless anyone responds with convincing info to the alternative.  Thanks for the advice.
Charles
Vittorio avatar
Hi Charles,
unfortunately I think that you can't have definitive answer to your question. A lot of people use an LP filter between filterwheel and telescope, others use an LP filter just on filterwheel (in place of L filter), other people don't use LP filter.
I know just one thing: everyone has problems!
personally I use an Idas P2 in place of L filter. some friend use Idas between telescope and OAG (so they can have LP reduction on RGB filters) but a lot of thimes they have reflection problems.
Sorry for my english :-)
John avatar
Charles Harris:
Chroma LP filter
the most of the pictures where done with a different camera...now i have a asi1600mm-c and use the uhc filter...only when i capture mid horizon targets. for zenith..i use the zwo clear glass...im living in a almost dark zone.soo...
I see..thx.
Vittorio:
Hi Charles,
Thank you Vittorio.  Very clearly put and valuable to know, I'm sure.  I will try to remember this as I get closer to a decision..I am going to check out all these filters you guys have told me about..
So long,
Charles
Mark Hudson avatar
Sorry it's a late reply, I use the Hutech IDAS in front of the filter wheel when imaging in LRGB and get good results with it under poor skies.  I usually remove the IDAS for Narrowband imaging.  For info the LRGB and Narrowband filters are all Astronomik brand.
Good luck with the decision.
Mark
Thank you very much Mark..
Peter Juhlin avatar
Im always shoot half of subs with uhc astronomik and half without any filter (ir- and LP removed)
Gothenburg city,  light pollution-grade 6-7
Best regards,  Peter
thank you so much Peter.  I wondered if anyone was doing that….Good to know.  I like your M101…very developed spiral arms…
Charles
Adel Kildeev avatar
Colleagues, Orion advertise planetary imaging filters set (UV, IR, CH4)  https://www.telescope.com/Orion/Astrophotography/Astrophotography-Filters/Orion-125-Specialized-3-Piece-Planetary-Imaging-Filter-Set/rc/2160/pc/-1/c/4/sc/63/p/113383.uts
Does anyone has these filters? Any good?  smile
RGB filters
I'm going to be getting an ASI1600MM soon and can't decide what to do about rgb filters. I currently have a set of Astronomik LRGB type 2c 1.25" or I could get one of the ASI1600 combos with the ZWO rgb filters and sell my astronomik one...
Compares Astronomik filters for light pollution, directly relevant to author's current filters.
Oct 13, 2018
L filter or light pollution filter?
Hi guys, I see a lot of guys out there imaging with a light pollution filter in place of the L filter. I live in an orange zone…should I consider doing that? woukd I have to expose longer with the light pollution filter compared to the L filter...
Compares light pollution filter options for LRGB imaging setups.
Jun 2, 2017
RGB Filter question - Baader vs Astronomik DeepSky
Hi, first off, I am almost certain this must have been asked before, but wasn't able to dig up a thread. Apologies! I am about to pull the trigger on a QHY163m + QHY 7-slot filter wheel in combination with my 4" TS Triplet APO and 3" Re...
Discusses Astronomik filters for LRGB astrophotography setups with CCD cameras.
Sep 15, 2017
