Planetary and Lunar Tracking with HEQ5
2 replies152 views
schmaks avatar
Is it the same process to track solar system objects as it is with deep space (polar align, star align, object align, shoot)?
Or—is there something else I need to know to track the planets and moon?
Well written Engaging
Eddie Pons avatar
There is a Tracking setting called "Lunar" on the handset.
Well written
Andrew Wall avatar
Tracking in Lunar rate for the Moon, normal Sidereal tracking for the other planets and stars. Solar for the Sun (with proper filters of course)
Horizontally aligning planetary images taken with AZ mounts
Hi everyone, Since I own only an Alt-Az mount, I'm looking for a software or technique that can help me in aligning multiple (Jupiter) final images, so the resulting animation comprised of these images, does not reveal the field rotation caused b...
Alt-Az mount alignment relevant to tracking solar system objects with different mount types.
Sep 23, 2021
Green bleed on moon processing using autostakkert 3.1
Newbie question on autostakkert 3.1. I tested some SER movies captured in SharpCap v4 pro last night; processed in AS!3.1 because it was fast and simple to do. Tested: a) Redcat 71 with ASI178MC on top (350 F/L); b) 127ED APO 0.7x red to ASI 533MC Pr...
Moon processing techniques directly applicable to lunar imaging workflow.
Feb 11, 2022
Does frame rate matter for lunar?
Forgive the noob question, but I am a noob with lunar! I've only been doing lunar for a couple of weeks and I am aware that I need to keep exposures relatively short to 'freeze' atmospheric seeing as much as possible (so I am generally us...
Lunar imaging frame rate considerations relevant to moon tracking and capture.
Jan 24, 2022
What IR-Pass Filter Do You Use, 685nm or 742nm?
Hello all you lunar imaging GURU’s! I have seen some of the incredible lunar images here on AB and obviously with excellent processing techniques there seems to be on thing in common. IR Pass filters to be specific. In doing some reading on what filt...
Lunar imaging filters and techniques applicable to moon observation and processing.
Jul 1, 2021
