midnightsnacks avatar
Hello, I am seeking guidance regarding rainbow artifacts around the bright star towards the top of the image and those thin rainbow lines.
What could be causing it, and how can I fix it?
The diffraction pattern around the bright star is consistent with petzval scopes, and I have yet to see the rainbow, however.
These are 60's exposures, 30 each RGB stacked and calibrated with 30 flats, 30 dark flats and 50 darks.
Processing is as follows:
Stacked/Calibrated in APP
PX Processing:
Slight Dynamic crop
ABE
BlurX
NoiseX
SPCC
Set up as follows:
AP mach1
Tak 106EDX4
ZWO 6200MM pro
Astronomik Deep Sky filters
Any input is much appreciated.
Much love,
Kevin.
Helpful Respectful Engaging
I suspect clipping of the marginal rays by the 48mm filters, if that is what you're using.
Problem identifying what my artefact problem is....
I recently imaged the Leo Triplet, and during processing I noticed this fairly big round artefact in my images. I could see this artefact in all channels. So tried turning my imaging train (camera, with filter wheel, OAG and TS-Optics Coma corrector ...
Author seeks artifact identification help; candidate discusses similar artifact problems.
Mar 24, 2025
Trouble with Deep Sky Stacker applying flats correctly
I'm having trouble with stacking photos lately and not sure what changed. I'm seeing dust mote artifacts in stacked & calibrated images that shouldn't be there. Below is an image straight out of DSS. No further editing, STF applied. Y...
Candidate addresses calibration issues with flats causing artifacts in stacked images.
Dec 9, 2024
Anyone know what could cause trange rings/colored banding around bright stars with Hyperstar v4 on 9.25" edge HD
Hello & Happy Holidays, I am encountering a new issue with all bright stars in targets I've been imaging the last couple of weeks. The brighter stars have bands or diamond shaped rings with different colors in wave like form around them. Plea...
Candidate describes colored banding around bright stars, directly matching author's rainbow artifact issue.
Dec 24, 2024
