Anyone know what could cause trange rings/colored banding around bright stars with Hyperstar v4 on 9.25" edge HD
3 replies240 views
Gina Knight avatar
Hello & Happy Holidays,
I am encountering a new issue with all bright stars in targets I've been imaging the last couple of weeks. The brighter stars have bands or diamond shaped rings with different colors in wave like form around them. Please see attached example of a 10 second image of Rigel. The issue is with 9.5" Edge HD using Hyperstar v. 4, ASI2600MC Pro camera and Antlia Triband RGB Ultra Filer II. I've checked the collimation 3 times using the "out of focus donut shape" method and it appears spot on. I've checked focus with Bahtinov mask and the EAF and it appears good too. I am using a black non-reflective dew shield and have the red LED light from the camera covered in black tape. Any ideas of what could be causing this issue? Could it still be some kind of tilt issue with Hyperstar? Or maybe an issue with the filter (the filter is 'frozen' in its holder in the Hyperstar and I need time to unlock it without damaging it so cannot remove it yet to test)? I've tried shorter subs 10 sec, 30 sec up to 60 sec with gain of 100 - all have the same result.
Any input would be greatly appreciated. Thanks so much for your time and clear skies to all!
Gina
Respectful Engaging
It's the filter. Not much you can do otherwise.
TiffsAndAstro avatar
Gina Knight:
Gina
Try it without the filter, and also replacing it with a UV/ir cut filter see the difference test maybe ?
Andrea, above is almost certainly right though
Gina Knight avatar
TiffsAndAstro:
Gina Knight:
Gina
Thank you both. Will try without the filter. At least that sounds like an easy fix!
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration causes star distortion; directly addresses diamond-shaped rings issue.
Nov 18, 2025
Comet shaped stars / stars with tails
Hello, I see this issue from time to time and I've never been able to fully put my finger on what it is. Maybe someone here could help me shed light on the cause for these odd looking stars. Some notes: It's consistent throughout the frame. T...
Addresses star appearance issues; discusses collimation and optical problems with bright stars.
Feb 28, 2023
Rainbow Artifacts
Hello, I am seeking guidance regarding rainbow artifacts around the bright star towards the top of the image and those thin rainbow lines. What could be causing it, and how can I fix it? The diffraction pattern around the bright star is consistent wi...
Candidate describes colored banding around bright stars, directly matching author's rainbow artifact issue.
Apr 18, 2023
Zenithstar 73- Are these stars bloating or I'm too picky again?
I recently aquired a W.Optics Zenithstar 73. I have the Flat73 adjustable flattener with it. This is my 2nd W.O. telescope so far, my first one was the 61, sold it after a year due to not liking how the stars looked like (pinched optics) Now, it look...
Discusses optical issues causing star distortion artifacts, relevant to your star quality problems.
Aug 13, 2023
