3nm Antlia Narrowband Filters
2 replies588 views
Kurt Zeppetello avatar
I recently upgraded my ZWO 7nm Ha and OIII filters with the 3nm Antlia Pro filters and could not be happier. I purchased the ZWO filters as part of a kit when I purchased the ZWO ASI1600MM 5 years ago. I have been very satisfied with the ZWO filters as the did their job for a relatively inexpensive price. However, as my processing improved my images seemed to reach a maximum detail/sharpness yet I suspect they could have been better. Since then Antlia introduced a 3nm Pro version of their narrowband and at a price that I could afford. Astrodon and Chroma existed but they were a little out of my price range. So how good are these filters? I made two YouTube videos which show the experiments and results:
Just How Good is the Antlia 3nm OIII Filter?
https://www.youtube.com/watch?v=WJZ-KWoS-KY&t=11s
3nm Antlia Narrowband Filters - Part 2) Hydrogen 3nm vs. 7nm
https://www.youtube.com/watch?v=J0r3NkIawEs&t=5s
Oxygen Comparison
I compared my new Antlia 3nm OIII Pro Imaging filter with my current ZWO 7nm OIII filter. Since I have an open position on my ZWO EFW, it was very convenient to make a good quality comparison. I hoped and expected the Antlia to perform better since it was 3nm vs. 7nm and I was not disappointed!
The experiment took place on 12-29-22 around 9 pm. I collected nine 5-minute subs of IC 410 using the ZWO OIII filter but only kept seven. I then switched to the Antlia OIII filter where I again collected nine 5-minute subs but kept eight. The temperature of the ZWO ASI1600 was set at -20 degrees C.
Some the highlights:
- smaller stars including no halos around large stars
- increased sharpness and detail
- better nebula definition
Hydrogen Comparison
I compared my new Antlia 3nm Ha Pro Imaging filter with my current ZWO 7nm Ha filter. Since I have an open position on my ZWO EFW, it was very convenient to make a good quality comparison. I hoped and expected the Antlia to perform better since it was 3nm vs. 7nm and I was not disappointed!
The experiment took place on 1-16-22 around 9 pm. I collected three 5-minute subs of IC 410 using the ZWO Ha filter. I then switched to the Antlia Ha filter where I again collected three 5-minute subs. The temperature of the ZWO ASI1600 was set at -20 degrees C. No post processing was done on any of the images.
- smaller stars
- slightly increased sharpness and detail
I plan on purchasing the 3nm Antlia SII filter in the near future.
Lastly, no processing was done on any of these images except stacking!
Fig 1 - ZWO OIII
Fig 2 - Antlia OIII
Fig 3 - ZWO Ha
Fig 4 - Antlia Ha
Tim Hawkes avatar
Hi Kurt,  very useful thankyou.  You have provided a nice practical answer to a question raised in this former thread https://www.astrobin.com/forum/c/astrophotography/deep-sky/how-much-improvement-does-a-3-nm-oiii-filter-provide-over-6-nm/
I have a 6 nm OIII filter and in theory (as KS_observer pointed out in the referenced thread) going to a 3 nm OIII should provide a 1.41 X improvement in SNR -- and your data seem pretty consistent with that expectation.
Improvement with the 3 nm HA filter is also definitely there too in your pictures.  Having an F4 and an F5 system  I think that the 3 nm OIII filter will work out so I intend to get one.   I will probably still stick with the 7 nm HA though because I do like to image HA in galaxies and 3 nm is too tight when you take into account the red shift.
Tim
Thanks for the info Tim. In fact I was only planning on just the OIII for and waiting to get the Ha and SII over the course of the year. I believe you are correct with the 7nm and red shift on faster systems. Cuiv, the Lazy Geek has some videos on this very topic.  - Cheers Kurt
ASI2600 vs ASI1600
Since my purchase of the ASI2600 to replace my ASI1600 I have been documenting my testing of this new camera to address a few specific concerns. You can read my posts at Sky and Rockets. The latest comparison image has also been uploaded to Astrobin ...
Documents narrowband filter upgrade experience relevant to camera testing workflow.
Apr 24, 2021
Mixed filter thicknesses and SW esprit 100 and asi2600mm
Hi, Is anyone using a Sky-Watcher Esprit 100 with its field flattener and an Asi2600mm pro camera with a ZWO filter wheel with mixed 3mm and 2mm thicknesses of filters? Would i just be able to re autofocus on each filter without any noticeable focus ...
Discusses filter thickness compatibility with ASI camera and ZWO filter wheel setup.
Nov 22, 2024
Can Someone Explain using Luminance Filter in High Bortle?
Hi all. I’m still new at the hobby. About 9 months in but I’ve come a long way since starting. With that being said I recently moved over to Mono imaging as I live in a Bortle 8/9 location (NYC). I specifically use my mono rig (Redcat 71 / AM5N / Ant...
Relevant to narrowband filter usage and mono imaging workflow discussed in post.
Sep 14, 2024
