Bright corners in OIII data with Redcat91 setup
Rabeea Alkuwariandrea tassellibobtobbAnakChan
34 replies643 views
Rabeea Alkuwari avatar
I’d like to seek feedback on a problem im having with my O data, setup is a redcat 91, using a 6200mm and chroma 2” mounted filters 3nm +LRGB. Problem seems evident on O data, non existent on Ha, S filters. And not as bad in LRGB. Camera + filter wheel are connected via M54 adapters to the telescope.
As you can see O data is bright on the corners, this can be taken care of with gradient removal tools, however if the image is stretched heavily the background becomes messy.
Please find the below comparison between Ha and O final stacks below📷 a19044b4-183a-49e3-a941-3f56417306a7.jpeg
a19044b4-183a-49e3-a941-3f56417306a7.jpeg📷 e32defe2-6429-4e17-836d-e85060bd473d.jpege32defe2-6429-4e17-836d-e85060bd473d.jpeg
This typically happens when there is a difference in the calibration files (as per gain and offset) between flats and lights (or even between flats and master bias/dark). Frankly, with a 3nm filter you should have really scant background light all.
andrea tasselli · Nov 14, 2025 at 06:41 PM
Hi Andrea,
Same set of darks/bias that were used to calibrate O also calibrated Ha. Not sure how it would affect O differently from Ha. Also gain is set at 100 for all frames and calibration frames as well
Weirder things have happened so do not underestimate the capacity of things to go belly up. I'd suggest you calibrate just the OIII frames first without dark or bias but with the flat and secondly without flat but with dark/bias and report back.
Concise
Jeff Rothstein avatar
How did you do your flats? This looks to me like a flats problem.
Well written Respectful
Jeff Rothstein · Nov 14, 2025 at 06:52 PM
Hi Jeff,
I use a flat panel and set the exposure on Auto using ASIAir, exposures are something like 5s-7s
andrea tasselli · Nov 14, 2025 at 06:52 PM
Will do…thanks
DavesView avatar
Just a guess here and may not be related. I hesitate to even mention it due to my inexperience. I have found a considerable problem with light leak on the RedCat 51 through the ruler window of the WIFD model. Key word here, WIFD. I chased the problem when using the ASI6200MM, Optolong SHO 3nm filter set and taking flats. It mostly affected the Oiii. Wasn’t noticeable at all in the HA and to a lesser degree, the Sii. A black cloth over the window is a permanent fixture now.
midnightsnacks avatar
Have you tried tuning your flats and re running calibration on the o?
midnightsnacks · Nov 14, 2025 at 07:19 PM
What do you mean by tuning flats?
Rick Veregin avatar
Odd that it is only one filter that does this. I can think of one possibility specifically for NB filters.
When light strikes a NB filter at an angle the wavelength band pass shifts. This is why faster lower F-ratio systems need special NB filters, the lower the F-ratio the greater the angle of the incident light cone on the filter, and the more the bandpass shifts. But also, the farther from the center of the FOV, the greater the angle of incidence away from perpendicular, and the more the shift. So in fast systems with a NB filter, the center of the image is brightest, the farther away from the center to the edges is darkest. All this depends then on how fast your system is, how narrow your filter band pass is (very narrow, definitely a stress), and of course how big your sensor is (full frame, another stress). The other thing is filters have an opacity to other wavelengths, this could change with angle too. And there are reflections from filters, so reflection/scattering might differ as well from center to edge. And finally this depends on the structure of the filter, its reflectivity, refractive index, thickness, and what band pass the filter is targetted to, and of course, exactly where the filter band width centre is positioned with respect to the NB line of interest. So behaviour can be very different with different filters.
All this being said, I would have though a correctly made flat would show the same behaviour as the light, and fix these types of problems. However, a very bright flat illumination can penetrate through the filter depending on it’s optical density and the angle, while the much fainter sky would not. Do note though, the more severe the vignetting, the more difficult it is to get a perfect flat.
Some things to try.
Don’t use any correction, and then see how bad the vignetting is with the different filters, is the OIII vignette much worse compared to Ha or SII without using any corrections for your lights? If so, the worse vignetting may be making your life much more difficult to get a good flat.
Make sure your OIII flat is not clipping or not too low at the bottom or too high at the top of the histogram, you want it to be in a nice linear region in the center of the range.
I don’t see how a bias or dark would affect this, as long as your bias and dark are good. I have had my bias and dark change on me suddenly, so make sure you do new fresh ones.
Personally, I always do biases, darks and flats in otherwise dark room, to prevent any stray light, doing flats in a bright room could result in a light leak somewhere in your system.
Rick
Helpful Insightful
Rabeea Alkuwari · Nov 14, 2025, 07:58 PM
If your master flat is over or under-correcting your lights you can tune it with pixel math using this
Expression: RGB/K = $T+ (n)
N would be the variable.
There are some good YouTube tutorials on it if you want to take a deep dive.
TiffsAndAstro avatar
not sure if you took different flats, one set per filter
Daemon de Chaeney avatar
Hi Rabeea,
Something you said makes me think you are using the same set of flats for all filters. If that were the case, that would probably be the problem, instead of having a set and master for each filter. Apologies if I misunderstood you though. The other thing to note is that 2” mounted filters are a bit narrow for the 6200 and usually unmounted 50mm rounds are recommended so you have less vignette and worse, no reflections off the filter mount which will definitely fall on the frame.
Cheers
Daemon
Helpful Insightful Respectful
Daemon de Chaeney · Nov 15, 2025, 09:41 AM
Hi Rabeea,
Cheers
Daemon
Hi Daemon,
Different flats are taken for each filter
John Hayes avatar
Rabeea,
A lot of things can cause this sort of problem and some of them have been covered in the answers here. The most common causes are either excessive vignetting or subtle stray light issues. You’ve said that the problem is “not as bad in LRGB”, which implies that the problem isn’t isolated to just a single filter and that it is visible with broadband filters. Rick’s suggestion that it might be due to the speed of the optical system is a good one but if you also see the problem with broadband filters, that may not be the only problem.
CMOS cameras generally have a very linear response curve; however, some sensors are not linear with very short exposures. How much exposure time did you use to create your flats? In general, as long as your exposures are longer than around 2 seconds, you shouldn’t have a problem. However, if you used shorter exposures, you could be running into a problem with linearity.
Remember that if there is no vignetting, no stray light, the sensor is linear, the darks are matched, and you use the correct math to do the calibration, it will always work.
AstroGadac avatar
Could it be a gradient from the moon one side and from LP on the other? Or moon on oneside→Meridian Flip→Moon on the other side?
AstroGadac · Nov 15, 2025, 06:33 PM
No this data is moon free
John Hayes · Nov 15, 2025, 05:21 PM
The IMX455 does appear to show this behaviour. My first flats with it were taken well under one second and despite being correctly lit and appearing more or less ok, were diabolically bad for calibration. I went to 3 second flats and have never had a calibration issue since.
Well written Helpful Concise
AnakChan avatar
I have been living with the ASI6200MM with overcorrected flats for about the past 4-5 years. Most prevelant with the Oiii filter (similar to the OP). I did not notice this issue with ZWO’s 2” mounted (I think they’re 7nm), but switching to the Antlia Pro 3nm unmounted, I see them on the Oiii.
I’ve tried :-
- on different my different scopes of different focal lengths and different F-ratio (Takahashi µ250CRS, Pentax 125SDP, Takahashi FSQ85ED) - note same imaging train(*) from tilt adapter to camera, but different appropriate extension tubes per scope.
- different gains (namely 0 & 100) and offsets (20, 50 100), and different temperatures (0C, -5C. -10C) ; and yes matching darks/flats/biases and new, not reused….also tried flat darks instead of bias)
- different flat sources - proper astro LED panels, tracing panels, sky flats, T-Shirt method, etc.
- different ADU percentages (NINA flatwizard) from 20% up to 80% in 10% increments
- (*) masking any potential light leakages between the camera & EFW, EFW & OAG, OAG & tilt adapter, etc.
- moved my filter masking around to see if a particular filter mask was introducing the issue
- loaning my Antlia Oiii to my friend who used it with his QHY600 and did not see any issues
So far no luck. Thinking is the camera left, I posted to the ZWOAsrto BBS forum as I was happy to pay for an ovehaul/refresh of my 5 yr old ASI6200MM. But, they suggested increasing my Oiii lights sub exposures (I was using 5 min), and higher flats ADU. Trying this, did improve with 10 min Oiii light subs, but not with 15 min light subs. I probably need to experiment more but after 5 years of trying different things, and having tried many different settings & combinations, I’m running out of ideas.
P.S. my note for the OP here is “You’re not alone with this issue”.
AnakChan · Nov 16, 2025 at 04:15 AM
I’ve tried :-
Feels good to know im not struggling alone 😅
Do you think its a manufacturing defect on the 6200mm or is it an issue known for all users? Also I havent tried stacking without flats, is it by any chance better without flats?
John Hayes · Nov 15, 2025 at 05:21 PM
Rabeea,
Hi John,
I usually target my flats to be above 5s as I know it will result in a better flat. Seems like @AnakChan is facing the same issue as me. Id love to know your insight on it since he has tried all the above suggestions to no avail
AnakChan avatar
Rabeea Alkuwari · Nov 16, 2025 at 06:19 AM
TBF, I really don’t know if it’s a manufacturing defect or not. But I ordered in late 2019, and received delivery in early 2020 - so I’m really one of the 1st batches. ZWO has revised the ASI6200MM since - specs seem the same but it seems to have a new external design/chassis at least. That’s kinda why I posted onto the ZWO’s BBS site. I’m happy to pay for an overhaul but seems they wanted me to try longer exposures and higher flats ADU.
I think I have tried stacking without flats but TBH, I need flats - primarily with the motes and dust spots, it’s so tedious to create synthetic dust spots to remove.
I’ll try try longer light Oiii subs again with greater ADUs, but that may not necessarily be practical for, say, bright targets where one may not want to have longer Oiii’s (in Bortle 6-7 skies) - balancing on sky fog with “long enough” subs to fix overcorrected flats would be a PITA.
I may try a different camera one day.
AnakChan · Nov 16, 2025 at 06:27 AM
FYI these heart nebula exposures are 10 mins on bortle 4. So im not sure if going longer can help (didnt try 15 mins). I have ordered this 6200mm around 2021 so we might have the same batch of cameras…I dont remember running into problems when i first used it on my F7 refractor. But things became messy when i tried it on F4.8
AnakChan avatar
Rabeea Alkuwari · Nov 16, 2025 at 06:31 AM
This is my thread on the the ZWOAstro BBS site:
https://bbs.zwoastro.com/d/25242-asi6200mm-flats-overcorrection
Feel free to piggyback on there and see what they say. Maybe there is an early batch issue.
And my old posts in CN: https://www.cloudynights.com/forums/topic/790962-yet-another-flat-overcorrected-calibrated-light-sub-issue-with-pixinsight/#comment-11388613
Reflections from a CDK 12.5
Below is an stack of six 10 minute Ha images taken with a Planewave CDK 12.5 scope under a bright moon. Severe reflections are evident. A similar O3 stack taken in the same run were nearly perfect. Both are Chroma filters. This would seem to point at...
Chroma filter issues with bright conditions; directly relevant to Ha filter problem.
12 hours ago
ZWO 6200MM and Filters
GDay all Is it ok to use mounted 2" filters or use 50mm round with a ZWO6200MM? Ta
Discusses 6200mm camera with 2" mounted filters; directly addresses similar setup question.
May 1, 2025
Serious Stray Light Issue - William Optics UltraCat 56
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope. I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The ...
Different telescope model; stray light issue may offer relevant troubleshooting approaches.
Mar 1, 2026
