Yes. I use Chroma 2" mounted filters with a 6200MM and here's what a flat frame look like. The extreme corners do get corrected. Ensure that the scope also support the image circle of full-frame.
[deleted]
May 1, 2025
The 6200 is a full frame sensor, and has a 44mm imagecircle. So the inner diameter of the filter needs to be bigger than that. A mounted 2" filter with most likely M48 threads is cutting it really close there and you might see vignetting, so you probably want to go with the 50mm round filters.
Appreciate the feed back and time for the image of the flat. Some set up there Brian; amazing gear. I will look at the 50mm unmounted. Chroma though will have to take a back seat though.. Thank you for your time.
Hi, I’d like to seek feedback on a problem im having with my O data, setup is a redcat 91, using a 6200mm and chroma 2” mounted filters 3nm +LRGB. Problem seems evident on O data, non existent on Ha, S filters. And not as bad in LRGB. Camera + filter...
Discusses 6200mm camera with 2" mounted filters; directly addresses similar setup question.
