Problem with Narrowband Normalisation in 1.9.2
9 replies1.2k views
Craig Dixon avatar
I'm having an issue where Narrowband Normalisation is giving me just a cyan image. See screenshot attached showing the image, the preview and the processing history. This is OSC data with a DNB filter (533MC Pro & L-enhance) in Pixinsight 1.9.2. Has anyone experienced this before?
Well written Engaging
Roy Hagen avatar
I experienced the same problem a couple a weeks ago, except the color was yellow.
I do not know if it is the same issue but, I pushed the reset button down in the right hand corner.
Worked fine since
Ian McIntyre avatar
From this screen shot It looks like your image is linear and is using ScreenTransferFunction. I'm pretty sure NarrowbandNormalization is meant for stretched non-linear images. I have not used it on linear photos so don't know if that would be the result, but that would be the first thing to try.
Edit: I stand corrected (or at least a tiny bit more experienced). Just tested an unmodified linear image and it worked just fine. Never mind.
Jason Schella avatar
Try linking the channels in your STF. NB normalization only displays appropriately with linked channels.
Philippe BERNHARD avatar
Yes, reset settings of this process,
cross on the bottom right of the process window.
If you have saved a process icon, you need to create a new one
Dave Stearn avatar
Craig,
I see in your workflow that you ran SPCC prior to Narrowband Normalization.
SPCC will mess up the colors when using a NB filter.
Bill Blanshan recommends that you run Background Neutralization and an Unlinked Stretch prior to NBN.
NBN normalizes the OIII and SII data using Ha as a reference. If you run SPCC and use a linked stretch it prevents NBN from doing its job. It’s a common issue and I have seen several YT videos where they are demonstrating the wrong workflow for this process.
Hope this helps. I have been a beta tester for Bill’s earlier scripts and have used NBN since it was released as a PI process.
Dave
Well written Helpful Insightful Concise Supportive
Klaus Haaken avatar
Agree. I experienced the same, but with a black screen. Resetting the tool helped in my case.
Well written
Dale Bush avatar
I have to reset the tool every time I use it since the update. Otherwise it behaves the same as before.
Well written
Thomas Rider avatar
I had to make a new process icon with it reset and saved. Weird bug but not permanent
Craig Dixon avatar
Many thanks everyone, resetting the process solved the problem so that's great.
Craig,
Dave
Thanks for the tip, I'll go back and remove SPCC from the process.
Well written Respectful
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
WBPP experiencing issues; similar PixInsight processing problem with specific module failure.
Sep 28, 2025
NoiseXterminator module not launching despite successful installation in PixInsight
I’m having an issue where all of a sudden NoiseXterminator is not launching. I’ve gone through all the steps of attempting to reinstall the module. It shows up in the repository and the dll is present on my hard drive. It shows up in the modules list...
NoiseXterminator module issue; similar PixInsight module installation/launching problem.
Sep 16, 2025
Weird artifact in CLSCCD images that won't calibrate away
Hello, I’m attaching two quick images taken on the same night (two different objects, saved as JPGs for size) - one HA, one CLSCCD filter (OSC camera). Flats taken with a panel that same night. If you look in the CLSCCD image, about a third of the wa...
OSC camera filter artifact; similar OSC data processing issue in PixInsight.
Sep 24, 2025
