Strange artifacts in picture of IC405
4 replies477 views
Ulf Jonsson avatar
I acquired 1 h 55 m by 23 exp of 5 min each of IC405. Telescope was Takahashi FSQ-106 and camera was ASI2600MC Pro.
During processing a strange form, like an arc with dark streaks from left to right in that area. I can't figure out why they are there. Can anyone explain to me what is wrong? Is it in processing, in camera, in telescope or something outside the equipment?
I have compared my picture with many of the other IC405 here on Astrobin but as far I can see no one else seem to have that problem.
Please help me if you can.
Off-field bright star. Plenty there.
Göran Nilsson avatar
Yes, I also think it is a bright star outside your field of view that is causing reflections in your imaging train.
Bästa hälsningar, Göran
Well written
Davide Manca avatar
Agree with the bright star, it should even be possible to understand which was the star…lok at the orientation of the picture and see which star is in that direction.
You could try exposing new frames but with a different rotation of the camera
My guess is HIP 24575
Jared Willson avatar
I agree with the others who described the likely cause. I have run into this issue before with my system as well. The only solution I have ever found is to take a second set of exposures composed differently so that the reflections are either absent or in a different location, then substitute some data from the second set of exposures for data from the first set using pixel math and a mask.  Works great, but requires an entire second set of data.  The only other solution I can think of is to see if you have the same issue in all channels. If not, you might be able to substitute, for example, some green data for your red just in the area of the arc, again using pixel math and a mask. You'd have to do some sort of linear fit, but that shouldn't be too hard.  This avoids the need for a second set of data but will only work if the reflection is visible only in a single channel.
- Jared
Halo artifact troubleshooting on Esprit ED80 and lens cleaning safety
I’m looking for some troubleshooting help with my Esprit ED80. I have this strange halo artifact on mid to bright stars (see attached image). If I rotate the image train, the defect follows the scope, so I know it’s there, and it is equally present i...
Halo artifact troubleshooting; addresses mysterious artifacts appearing in processed images.
Nov 26, 2025
Planetary and Moon camera
I have a Skyris 274M camera for imaging the Moon, the Sun and some planets. I am considering an upgrade to one of the ZWO color planetary cameras. Can anyone guide me to the BEST choice? I will use it together with Orion Optics ODK-10, William Optics...
Uses Takahashi FSQ-106 and ASI camera; relevant for planetary imaging comparison.
Dec 22, 2021
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
ZWO ASI 2600MC camera producing artifacts; matches your camera model and symptom.
Nov 27, 2025
ASI2600MM Pro Streaking Issue
Hi, I have some weird streaking issue down the center of my pics when using my ASI2600MM Pro. I'm using it with a 2" EFW and have noticed it on all of my filters. Any ideas? I tried to clean the outside sensor, which fixed an oil/grease issu...
Strange artifacts appearing after processing; similar camera model involved.
Jan 11, 2022
Strange circles in my image
Posted is a screen grab from Pixinsight. This image is very curious to me because I'm not sure whats going on here. So some info 51 images stacked in Siril, with no flats, darks, biases or dark flats. I wanted to see the raw image with no calibra...
Strange circles/artifacts in images; similar troubleshooting approach to your arc problem.
Apr 2, 2025
