Advanced Searching
2 replies137 views
Lightpath avatar
Hey so I would like to use Astrobin to find objects to image with my system.  So I'd like to be able to do more advanced searches like:  deep sky where image_scale=0.8 AND constellation=Pegasus
Is it possible using the current search constructor to do this type of search?  I know the listing of equipment is basically a free for all, so searching for "130mm refractor AND asi1600mm" is probably going to be hard.
Are there any plans around having an "advanced advanced search" where we could basically use SQL to formulate elaborate searches to identify specific objects with specific equipment?  Such as:  "130mm AND refractor AND icx814" or something with value pairs?
Thanks very much, I  am enjoying using the site!
Salvatore Iovene avatar
Hi!
I don't think I'm going to have time for an "advanced advanced search" that allows for a query language... but:
  • Search for "130 ASI1600" should get you close[/*]
  • You can narrow it down to refractors[/*]
  • You can narrow it down to pixel scale between 0.7 and 0.9 (based on plate-solution)[/*]
  • Constellation search is coming soon, but you can search by RA and dec ranges, just add the filter[/*]
Search by telescope type is not going to be perfect, because not everybody specified that. But it's going to be solved soon because the first thing I intend to do with my new found time (starting November I reduce my day job to 4 days a week) is clean up the equipment database.
Lightpath avatar
Cleaning up the equipment database will be a HUGE improvement!  Thank you!
Those are very helpful hints on how to search, thanks!
Planning process and planning software?
Hi, I started with AP in September this year and I'm wondering how you plan your Imaging sessions. In first place, how do you decide on the objects you intend to image? As a beginner obviously I get a lot of inspiration by images published here a...
Discusses planning imaging sessions and deciding which objects to image.
Dec 23, 2021
Is anyone using EAA for object scouting?
I recently got into EAA when I couldn't resist a huge discount on the Unistellar eQuinox. I find it a fascinating supplement to astrophotography in particular for a beginner. I started to use it to scout potential astrophotography targets. I alwa...
Mentions using EAA for object scouting, relevant to finding objects to image.
Jul 4, 2022
