Anthony (Tony) Johnson avatar
Was thinking of upgrading my mount to the EQ6-R pro, I use a MacBook Pro right now, and was wondering if PHD2 will recognize the mount through USB and be able to guide the mount. I have a ZWO120mm mini guide camera which is recognized in PHD2 so I was hoping it was a simple matter to connect the mount through USB and guide this way. Otherwise I guess I could use the ST-4 port but I’ve heard that’s not the greatest way to guide your mount. I know that MacOS doesn’t support ASCOM drivers. Any help before I make the purchase would be greatly appreciated.
Is it got Apple Silicon chip or is it still Intel?
Oh yeah that might help huh, Intel I7 16gigs. It’s a 2012, still a workhorse.
Then yes, you should have no issue with PHD2. At least I didn't. Not sure there is an INDI driver that needs installing as I don't use SW mounts but you can check with Ekos (KStars - Desktop Planetarium (kde.org)), which I would highly recommend to install if you are using OSX (if you can bootcamp on Win 10 then maybe NINA is a better option).
Alex G avatar
I have M1 MacBook and motorised EQ3-2 mount (this should not make much difference in terms of hardware connection and drivers, my mount shows up as "HEQ5/EQ6" in the interface), and I am actually using Windows 11 running on a virtual machine in Parallels. Everything works fine.
I found Ekos/Kstars not as user friendly as NINA, there are less materials about Ekos/Kstars, and NINA has much better polar alignment functionality which is very important to me. Parallels is a paid software, and probably Windows will be for you as well, so you can consider this option if you are willing to pay for that.
One more thing to be aware of – I had some troubles with ASI camera drivers for M1 specifically (now resolved), so make sure they will work for your Windows setup beforehand.
Yeah I run windows 10 on boot camp. Got parallels too. I just fine the MacOS much more user friendly. I was just hoping like my ZWO guide camera the sky watcher mount would just be in the drop down list to select. In other word easy. I’ve tried the other apps and found them with a high learning curve or just plain clunky. Would rather just stay on the Mac side of things if I can. Why I put the query out to the community. Thanks for you input though.
DISCONNECTION WITH IOPTRON COMMANDER
HELLO EVERYONE I have an ioptron cem 120 EC2. Randomly the ioptron commander application disconnects saying that it can't find any devices anymore. Looking in the USB peripherals I see the mount connected. The only way to reconnect the applicatio...
iOptron mount connection issues may relate to USB/driver problems author faces.
May 22, 2025
Anyone successfully guide with an iOptron HAZ31, HAZ46 or HAZ71 strainwave alt/az mount (plus a rotator)?
As far as I know, there is no ST4 port on any of the HAZ mounts. I have read posts of people trying unsuccessfully to pulse guide HAZ mounts using PHD2. I'm wondering if anyone has tried the Direct Guide option in PHD2 with a HAZ mount, or found ...
Discusses ST-4 guiding limitations on mounts, directly relevant to author's concern.
Apr 22, 2025
