Rafael Amarins:
Hi
I have a 102mm F7 Triplet Apo
Dawes Limit for this aperture is 1.14"
I'm currently using the IMX294 which gives me 1.34"/pix which for the aperture should be an appropriate sampling for the setup.
The thing is I just bought a Player One Uranus C Pro which gives me 0.84"/pix so I know I'm oversampled when using it
I know seeing is a limiting factor but apart from that I have some questions and I would like to hear from other folks who went through this situation.
Should I notice this change in detail?
Should the new techniques envolving deconvolution give me advantage post processing?
I understand focus, seeing and guiding are the main concerns but considering I'm having ideal conditions for all three what should I expect?
Whether you will see a change in resolution will depend a lot on your seeing conditions. For example, I have a 12" scope at a remote site that is sampled at 0.69 arc seconds per pixel. Right now, the scope is imaging... The seeing monitor reports "2.4 arc second" conditions which is perhaps a bit below average for the site and probably about average for mid norther latitudes in North America as a whole, though there is obviously a lot of variability. The object I am imaging is fairly low at the moment, just 33º above the horizon. That will erode resolution pretty noticeably since the scope is looking through a lot of air compared to something at zenith. The scope is fully equilibrated, well collimated, well focused, and guiding is hovering around 0.4" RMS which is pretty good considering altitude and seeing conditions. The mount is perfectly capable of <0.3" RMS with better seeing and nearer zenith.
I just checked a five minute sub exposure to see what the FWHM numbers are... Eccentricity (as reported by PixInsight) is just under 0.4 which indicates guiding is, in fact, reasonably good. FWHM is running 3.2 arc seconds. That means each star is more than 4.5 pixels across. Your 102mm scope with the IMX294 would probably be a little oversampled for these conditions, let alone my 12" scope at 0.69"/pixel.
Is there something wrong with my scope? Or my guiding? Or my focus? Nope. On a night of better seeing (or even later tonight when my subject is higher in the sky) it will do very well. It is perfectly capable of five minute sub exposures with resolutions better than 2" FWHM. But on an average night? With a poorly placed object? Not so much.
The new deconvolution utilities such as BlurXterminator do a really nice job. They especially do a nice job of using different PSF profiles in different parts of the image (if you have a little tilt or some off-axis astigmatism). They can draw out existing details in nebulosity making them much easier to see. And they seem to do this all without introducing annoying halos and without significantly impacting noise levels. Pretty cool. But will they do a better job with your higher sampling rate? Well, if everything else is good, sure. But if you have a night of mediocre seeing? Or if your subject is low on the horizon? Or if your guiding is not quite as good as you hoped? I doubt you will notice a difference.
Moving from 1.3" to 0.8" per pixel will allow the possibility of more resolution in your images (both before and after deconvolution), but it won't guarantee anything. Everything in your imaging train has to be working well for you to realize any gains. As you yourself mentioned, focus, seeing, and guiding will still have a bigger impact. As you probably already know, improving resolution in deep sky imaging (without resorting to lucky imaging) is all about incremental gains. Higher sampling rate? Maybe you'll get an extra tenth of an arc second or two. Better guiding? Another tenth. Improve your collimation? Or your flattener backfocus spacing? Maybe another tenth. An extra couple inches of aperture? Maybe another tenth/maybe just better SNR. All the little improvements add up. Moving from 1.34" per pixel to 0.84" per pixel is definitely good--if everything else is optimized. I would think of it more as a prerequisite to <2" FWHM subs, though, not as a guarantee.
