processing data
3 replies220 views
Dennis Spender avatar
Last evening was my first attempt at capturing a DSO. I shot lights, darks, biases and flats of M31 with my William Optics FLT 91 on an EQ6-R Pro with my Canon T3i Rebel. The light images look nice.
The question: These files are on the SD card of the Canon. I will copy them to my D drive (HD). Should I name each file for its content, ie light1.fit, light2.fit, dark1.fit, etc or something different? I plan to ultimately have a folder for each group on D under the main title M31. I will then copy the appropriate group over to drive C (SSD) for processing.
Thanks
Christian Großmann avatar
Hi Dennis,
I used to use Deep Sky stacker and now PixInsight. If I remember correctly, both programs don't need files with a proper name. With DSS you can select all flats, then all darks, all biases and all light frames. It doesn't matter how they are named. In Pixinsight, you can select the single files as well. A more comfortable way is to have folders with the names dark, flat, bias or light somewhere in the file path. So naming the folder correctly is a plus. This way, you can give PixInsight the main folder and it detects every sub automatically which saves a bit of time. I guess, other stacking programs work the same way.
However, it may be a good idea to sort the files in a useful way. So some system is recommended. Personally, I use NINA to capture the images and let the program automatically rename the files with a given template. This way, I see some imaging details in the folders without the need to open the images in some program. There are some free tools like Kuknet file renamer out there, which can easily rename the images automatically to your taste afterwards.
I began to sort my own images with the following system (all folders):
Object type (Deep Sky, planetary, comets, etc.)
Object name (usually the NGC catalogue number if there exists any)
Telescope I used (with reducer/corrector)
Camera I used
RA_DEC
Camera angle
Date
Frame type
As you can see, I use a lot of folders. But this way, I am able to add more data to images later on and I can easily work on long time projects.
This is my own system. It works well for me. I use it for some time now. It may not fit to other persons interests. Before that I used some different method which always had its downsides.
Clear skies
Christian
I like that schema Christian. Thanks for the thoughts.
Oscar H. avatar
For me, I have my lights, darks, biases, an flats sorted for every DSO object. So, for example, I have a folder named Orion Nebula; inside the folder I have 5 folders, lights, darks, biases, flats, and master lights with master light revisions (edits, which I just call "versions", like V1, V2, etc…) in the fifth folder. Probably a newbie way of doing it. Got basic idea from Nebula Photos I think.
I like things easy to understand in this hobby…
Concise
Issue in frames calibration?
Hi everyone, this is a long post, but it’s needed to provide proper context. Thanks in advance to anyone willing to read through it and help me figure things out! I’ve been struggling for days with what seems to be a calibration issue (or possibly a ...
Jul 8, 2025
Both posts discuss technical challenges that astrophotographers face when processing deep sky object images after capture.
Crescent Nebula raw data available for processing - 21 hours collected
Hello all, The time has come again to offer up some of my raw image data for anyone to process if you’re up for it, specifically my 2025 acquisition of the Crescent Nebula in Cygnus. I captured this in a relatively narrow FOV with my Celestron C6 sco...
Both posts discuss the management and sharing of raw astrophotography image data captured with telescopes.
