Williams 71 gt with rotator back focus
5 replies346 views
Dan Kearl avatar
I have my Williams 71 gt scope set up perfectly with back focus of 64mm..
I bought a Rotator because Williams is too cheap to have one and when I put it on it messed up all the focus,
I cannot even polar align now.
Has anyone had this problem? I took to off after screwing around for an hour and it works fine again.
What do I set the Flattener at with the added rotator to get the Scope in focus again.
I have an EAF attached.
Mark Germani avatar
Where is the rotator attached - between the OTA & flattener, or between the flattener and camera? AFAIK, it should be between the OTA and the flattener, and then you don't need to touch the backspacing between the flattener and the camera.
If you're using an EAF, did you get it roughly in focus before starting your autofocus routine? If it can't identify any stars to use as a reference, the autofocus will fail.
Sorry if these are all things you've considered. CS!
Well Written Helpful Respectful Concise Supportive
Tarun Pulikanti avatar
I have a rotator attached to my GT71, it goes on to the scope before the Flattener and you dont have to touch the back focus !!
John P avatar
Dan Kearl:
I have nine set to ~9.5mm on the flattener and it works fine. I think the guide says 9.1mm.
Dan Kearl:
Yes I have a similar setup !! Below is a image of the same !!
Pariah avatar
If you have the 1.0x TS Flat it can cause issues if set up as rotator - flattener - backfocus- camera. The focuser extension is only 10mm with the TS flat so you wont get focus if you add a wo rotator
Which flattener are you using?
Manuel rotator and ZWO asi 55mm space for camera.
Hi. I’m looking at getting the WO Manuel rotator to frame easier and am looking to put it just after my scope and before my reducer / flattened on my WO ZT81. Will it mess with my focus at all for my camera and if so will i have to reduce the 55mm ba...
Rotator back-focus compensation on similar scope setup.
Jan 31, 2022
Can someone help me, bought a used RASA and unsure how to connect
Hi, I bought a used RASA, and there appears to be some kind of attachment to the front that I cannot connect to(see images). My understanding is that you use the camera adapter plate and a retaining ring to screw on the front. The scope appears to ha...
Discusses attachment/connection issues with imaging equipment setup problems.
Jul 15, 2025
iOptron load/noise
I have an Ioptron cem26 mount. When I do polar alignment and it rotates 60 degrees it clicks. The equipment weights 16 lbs, AT115EDT, Canon 600D, ASIAIR pro, ZWO mini scope a camera. This clicking started when I switched scope from AT80ED. That set u...
Addresses polar alignment issues with mount rotation, similar problem domain.
May 29, 2025
