Flat files showing "central obstruction" of Skywatcher 130PDS
4 replies283 views
Kristof Vandebeek avatar
I have a Skywatcher 130 PDS, and for imaging I have a TS GPU coma corrector, 5 position filter wheel and ASI533MM. For my flats I use a fairly thick white opaque acrylic plate and this has been working well - it calibrates out dust and vignetting.
But one thing keeps bothering me: it looks as if the central obstruction of my newtonian is visible in the flats that I create. I don't have any experience with other newtonians, so my question is "is this a common issue" or is this something specific in my setup?
Extra information to triage this problem:
  • I have attempted to insert only my camera into the focuser and the issue then still occurs - so I think it is safe to assume that this rules out that the coma corrector or filters/fliter wheel or any extention pieces are causing reflections
  • The issue decreases/disappears if I move my "imaging equipment" further out of the focuser
  • The "central obstruction" that I think I'm seeing moves slightly when I rotate my "imaging equipment" in the focuser
  • Increasing/decreasing the brightness of a light bulb that I use while creating flats doesn't make much difference
  • When closing my 130PDS with the dust cover and exposing it to bright daylight or very bright LED bulbs, there are no light leaks (eg: a 15 second exposure will show same ADU levels as a bias frame)
  • I think my collimation is fairly OK (secondary looks round in a sight tube and appears to be fairlly centered, collimation with a collimated laser collimator looks OK, collimation with a barlowed laser collimator looks OK, stars appear round when I image and Siril lists the average roundness usually around 0.90 to 0.94, Astap shows limited tilt (usually around 3% when inspecting images))
Following image shows the problem (the center is darker):
Following image shows what I get when I move my imaging equipment further out of the focuser:
Brian Puhl avatar
I would just attribute it to vignetting, however your vignette is not centered which leads me to believe your collimation and or offset are off.   Might want to work that collimation a little better.   When it's proper, your vignette will be centered with equal light falloff on all corners.
Erik Frank avatar
I have the same problem with my 130PDS, when my light source or the sky is to bright. Than the secondary is visible with its shadow and that doesn't fit with the flat from pure optical path. Using less light always worked for me.
CS Erik
Michael Ring avatar
As I saw you wrote that you moved the focusser, please make sure that you do you flats while the telescope is in focus. Here's an example for my PDS 130, please also note that the  brightest spot is (roughly) in the center... I am using the Baader Coma corrector...
Nothing wrong with it, after all the secondary *does* shadow the primary thus both the inlet and exit pupil of the scope and having a small light drop-off is only to be expected and the contrastier the image is the easier is to see it. As you move out everything fuzzes up a bit as you move out in the caustic cone.
Cheap Newtonians and a coma corrector are actually pretty cool!
Ignore my processing, but I wanted to highlight to newcomers on here that you don't need to spend thousands on your first scope (OTA) to get nice sharp images. The equipment here is a Skywatcher 200 DPS 8" Newtonian together with the Skywatc...
Similar Skywatcher Newtonian model; discusses imaging setup and accessories.
Mar 28, 2022
extreme offset vignetting in flats and lights
This issue has persisted for a while now through at least 3 set ups and I honestly cannot for the life of me figure out what is causing this. Here is an image of one of my flats which displays the extreme offset in vignetting in my imaging train whic...
Discusses vignetting issues in flats and lights, directly relevant to author's concern.
Nov 9, 2025
Please help – first light disaster
This is the result of the First Light session with my new RC12 https://www.astrobin.com/r1jjrs/ On the Original you see the picture without flats applied Rev. B is the same picture with flats applied Rev. C Is the master flat and its curve to create ...
Author uses flat panels; discusses flat file creation and application techniques.
Feb 11, 2022
Gardient on OIII flat frames
Hi, I noticed that my integrated OIII images have an odd gradient from left (bright) to right (dark). I was able to trace this back to the flat frames - below is an extracted background to highlight the problem. Looks to me that the left part of the ...
Discusses flat file issues that may relate to your gradient problem.
Feb 23, 2022
