Stripe pattern: Baader UHC-S + ASI1600MMPRO + street light
5 replies193 views
Hans Widmer avatar
Dear All
In my black and white photos of the galaxies you can easily see this annoying stripe pattern especially in the lighter grey parts of M 101.
In my photos of the nebulas you cannot see this pattern.
Therefore it must have to do with the filter typ as a first guess.
For the nebulas I used the Baader Ha filter. For the galaxies I used the Baader UHC-S filter.
Could it be possible that this pattern is dependent of the manufacturer of the filter?
Should I try another manufacturer e.g. an Astronomic CLS-CCD filter or so?
Could it be possible that this pattern is a kind of polarization?
Should I try to rotate the filter of about 90°?
I don't know what to do to get rid of this pattern.
Can anybody help out there?
Thanks a lot.
Best Regards
Hans
Hans Widmer avatar
I think I can answer my own question.
I have identified that I had used the same darks and bias for the galaxies pictures which I had used for the nebula pictures.
My exposure settings for the nebulas is gain 200 and offset 30 because of the Ha filter.
But my exposure settings for the galaxies is gain 50 and offset 13 because of the UHC-S filter.
I made now a new set of darks and bias with gain 50 and offset 13 and used them for the calibration of the galaxy NGC 5907 pictures and the stripe pattern has vanished.
Obviously the setting of gain and offset matters for the darks and bias.
I think the problem has solved.
Result:
I have to develop the pictures of the other galaxies again - with the correct darks and bias.
I guess that I will never make the same failure again.
Christian Vulpescu avatar
Wow. Hans, that was very good. I have the ASI 1600 mm Pro cool and hat the same problem but with nebulas.
I will try your method.
I have the ASI1600 mm pro, too and had some vertical and horizontal banding. It disappeared after dithering.
Hans Widmer avatar
Christian
Because I always do dithering without guiding and use drizzle integration functions on PixInsight I have no experience how my pictures would look if I wouldn't dither and drizzle.
Hans
Hey Hans,
You do it right if you dither. I've tryed it once on the Wizard nebula without and the result was a lot of banding.
This was my first and last time, I have had banding issues with the ASI 1600MM Pro.
Best regards,
Christian
Best way to combine Ha channel from more than one Ha filter (e.g. Antlia Ha + Antlia ALP-T + Optolong L-eXtreme)
Too many clouds in the last days and only a small window of hope next week, so I spent the last days on re-processing old data and an interesting question (for me) popped up where I'd love to hear your thoughts: I do narrowband imaging with an OS...
Discusses multiple Ha filters and their characteristics in astrophotography imaging.
Apr 24, 2022
