Shooting SHO (Hubble Palette) with DSLR?
Hubble Palette Group 1 reply91 views
schmaks avatar
Hi there,
I am considering upgrading my setup with a narrowband filter/wheel but first wanted to know if it works to shoot SHO with a DSLR?
If anyone has any experience with such, can they please share?
One question I have is would I then need to set my DSLR settings to be shooting monochrome?
Nicolas Eon avatar
Yes you can shoot « SHO » with DSLR using narrowband filters using OSC (Colour Single Shots).
Actually, you need to know that when you shoot monochrome with your DSLR, the image is captured in colour through the Bayer Matrix (Most often RGGB) and then your DSLR transform the colour image into  Monochrome. Therefore, shooting in monochrome with narrowband filters does not help.
Here is what you need:
* You must have an astro modified DSLR (removing the native IR-cut filter of your sensor) in order to increase the sensitivity to Ha
* Use Dual band filter like Optolong L-extreme (or other dual band filters) design to block all wavelength except Ha (656nm) and OIII(ca. 500nm)
* Take colour shots
* In post you can extract the Ha and OIII signal separately
* In post you can create a « synthetic » SII signal by combining Luminance, Ha and OIII signals. The many different way to proceed
* You can create an RGB image using the Ha, OIII and SII signals you have previously extracted and place in the right channel.
Note: Instead of creating an artificial SII channel  you could also take colour shot with an SII filter and extract the Red channel in post. But you need to know that usually SII signal is much weaker than Ha and OIII. Beacuse of the bayer matrix, you will need lot of exposure to have a good SII signal
Here is what you can achieve with such a method : https://www.astrobin.com/gicvax/ . In the comment, I share the method I use to extract Ha and OIII channels, create a synthetic SII channel and combine Ha, OIII, SII to create colour RGB image.
If  you want to do real SHO, you need a monochrome camera (no bayer matrix) and use separated filters for each wavelength (1 for Ha, 1 for OIII, 1 for SII and usually 1 for Luminance). But I don’t think this what you want to do at this stage.
I hope it will help you
Helpful Respectful
1.25 filter for APS-C?
Quick one to know the limits of the 1.25 filter. I'm hoping to upgrade my narrowband set to a 3nm set. my current setup runs fine with 1.25" filters. So obviously that is what I'm looking at to purchase. But, in the back of my mind, I do...
Discusses narrowband filter upgrades for APS-C DSLR cameras.
Nov 29, 2021
New to narrowband (SHO). Suggested exposure times? Calibration frames, etc?
Hi! Stepping into narrowband with a 183GT, shooting SHO and need some tips. My setup is a ZS73 scope on a HEQ-5 Pro Mount with ZWO guide system, etc. How long should my exposures be? How many calibration frames (darks, flats, bias) should I need and ...
Directly addresses narrowband SHO shooting with detailed setup guidance.
Apr 8, 2022
