celestron starsense explorer 130 dx
4 replies71 views
tago064 avatar
Anyone have this telescope and know how to use it?I have a problem that the nearby planets like Jupiter and Saturn I can not see clearlyIn contrast I saw the moon excellentlyWhen I aim the telescope at Jupiter I can only see it from a distance, along with its moons, but when I zoom in I see it really not clear with a big black dot in the middle.I know you're not supposed to see that, and in this telescope other people have seen quite clearly.Maybe this is a problem with the telescope tuning and the sync of the app?
dkamen avatar
You are mistaking the focuser for a zoom knob.
dkamen avatar
So basically:
1) Zoom is always the same with a telescope. It is not like a zoom camera. The only thing changing the zoom is the size of the eyepiece you are using. If you want larger zoom, use a smaller eyepiece, e.g. 10mm will give you 5 times more zoom than 50mm.
2) The thing you are turning changes the focusing. When you turn it Jupiter does get larger but that's coincidental, in reality what happens is it defocuses: instead of a sharp little Jupiter you see a larger and fuzzier circle, and yes there will be a black circle in the middle after a certain point.
3) You want to turn the focuser in the opposite direction, until the image of Jupiter is a small (and sharp) as possible) and the black circle has disappeared completely. Best to use the moon for focusing because you know what it should look like. And then simply turn the scope towards Jupiter.
tago064 avatar
Plus I still haven't been able to properly target the app.Could it be that it has a connection that I can not see well?I was able to see the moon sharp and clear but it is the closest object to Earth and easy to aim at.Until now I have not really been able to direct the telescope along with the app
tago064 avatar
I'm already desperateEvery time I try to aim the telescope at a planet, I fail to see it sharply and clearly.You could say that with a telescope I can not aim at the center.I tried to aim the telescope with the red dot several times before during the day and every time I came to aim at a star I saw the black point of aiming and a shape of like a flashlight from the outside, only a little farther I saw a star shape, when it is really small.It happened to me on both Mars and Jupiter.I no longer know what I'm not doing well.
smile smile
Newbie from Bortle 8 London UK
Hi Everyone, About 50 years ago, I was a keen amateur astronomer in Melbourne Australia, and I'd like to get back into astronomy and astrophotography, but boy have things changed in 50 years! I'd like to be able to image DSO, the larger plane...
Returning astronomer seeking to reconnect with hobby and troubleshooting basics.
Oct 31, 2021
TSMKOLLI Collimation
I recently received the new TSMKOLLI collimating tool for use with my Newtonian and RC telescopes. I’m fortunate to have had good results collimating both telescopes with just a laser and Cheshire. However, with the Newt getting into awkward position...
Collimation tool discussion directly addresses telescope tuning and alignment issues.
Apr 28, 2022
