Beaver(Alejandro) avatar
how to fix the horrible banding?  Would dithering do wonders to the banding?
Rick Schneider avatar
In PixInsight, under Scripts/Utilities - CanonBandingReduction does a good job of removing horizontal banding.
Well written Concise
Behnam Darvish avatar
Siril is free and has a banding removal tool that works great. If you have banding in both directions (horizontal and vertical), you can rotate the image and apply the algorithm to the other direction as well. The banding removal tool works on the stacked image or you can apply it to individual subs prior to stacking them as well.
Well written Helpful Concise
Thanks both of you!!! I unfortunately dont have Pixinsight but i never thought to flip the image vertically. Thanks!!
Dithering stops on TSX/NINA
hi, i am running a scope on an Software bisque MYT using the SKYX and NINA. i am not using a guider and instead use direct guider to enable dithering. During the course of the night dithering stops and the following error message appears - ASCOM driv...
Directly addresses dithering implementation, relevant to author's question about dithering effectiveness.
Apr 6, 2025
