ASIair Plus with Sony a7II?
10 replies515 views
Kevin McAskin avatar
I was wondering if the ASIair Plus is compatible with the Sony a7II mirrorless camera. I am hoping to use it to automate my imaging process and start to auto guide my setup. Any help is appreciated.
John Sims avatar
It is shown in the list of supported cameras, but with an * indicated it is "untested". Scroll to bottom of this page (https://astronomy-imaging-camera.com/product/asiair-plus/) to see the list of supported camera. I guess it will work. However, this is NOT full support as you might get with ZWO camera. See the following links for more info: https://bbs.astronomy-imaging-camera.com/d/11079-dslr-control-with-asi-air/7
I think you will need a separate guide scope and guide camera.
Concise
V avatar
Yes, it is, and to great effect. Infact it gives better readouts with the ASIair writing to FITS. Have fun!
John Sims:
All A7's, and all other modern Sony Cameras are technically fully supported, as the internal-external control firmware is the same across almost all camera models. It should be fine. Plus ZWO's "Tested" sheet only describes the cameras that ZWO themselves have tested, not users. I've seen 5 A7II users on ASIair, and they've all said it's great.
John Sims avatar
John Sims:
V.M, what adapter do you use, and could you describe your imaging train behind the flattener?
Thanks,
Joey Troy avatar
This may help a little as well.
https://joeytroy.com/sony-a7-iv-asiair/
V avatar
John Sims:
John Sims:
Thanks,
Hi John, I'm not using the Edge HD 8's .7 Reducer, it reduces quality of picture at the cost of a smaller field of view. Definitely a waste of money in my book. For my A7III, I'm using the Baader Sony E mount M42 T-Adapter, using the Edge 8's T-Adapter, ZWO OAG, ZWO M42 Filter Drawer, and some M42 spacing rings. I'd like to go up to M48 so I can use the entire field of view the baffletube affords, while not having an encroaching OAG, but the Edge 8's main T-adapter does some overlapping of the wider opening- unfortunately. But that won't happen since I'm going off to the Navy in a week  14HD here I come!
John Sims avatar
Thanks V.M. Good luck with your Naval duty. Guessing you will enjoy it, and clear skies with your 14HD.
Chris Beere avatar
Yes it is compatible. I have an A2 that i have tested successfully with the ASIAIR.
Unfortunately the data is garbage, you have probably heard about star eater, its really bad.
V avatar
Chris Beere:
That sensor is a beast, but star eater crushed any advantage it had.
John Sims:
Hi. . .
I signed for NUC, so I'm going to need that luck, best job I could ask for, but it'll be tough. Looking to do science with that big boy while I start my astronomy career.
John Sims avatar
Gotta love a challenge. NUC and Astro, quite a combination. As H. Ross Perot was fond of saying "The devils in the details".
Imaginalcala avatar
I’m trying with asiair and sony A7II but I have a problem. When I using, for example, Live, it doesn’t stop properly when I trying to stop it. Not only this, when it finished the app freeze/crash Any idea? I try with different wires A7II/ Asiair
iOptron Skyhunter and ASIAir support
I've an iOptron Skyhunter with iPolar, I am planning to get ZWO ASIAir Mini computer to control my set up but unable to get any resource saying if it is compatible with the mount or not. I've checked ZWO support website and this mount is not ...
ASIAir Plus compatibility question with different camera/mount combinations.
Jun 11, 2025
Best thoughts for mounting ASI Air Plus on refractor.
Good afternoon all, Just got the ASI air plus in intro to auto guiding and I am super excited. Currently trying to figure out the best spot to out it on my mount. I've seen people placing it underneath the plate at the front, I've seen people...
ASIAir Plus mounting and auto-guiding setup guidance directly relevant.
Apr 15, 2025
Exposure time recommendations for my setup
Hello everyone. First let me list my equipment: Telescope: William Optics RedCat 71 WIFDCamera: ZWO ASI585MC ProMount: ZWO AM5NGuiding: ZWO 30mm Guide Scope (120mm) + ZWO ASI120MM MiniAccessories: ASIAIR PlusFilter: Antlia Quad Band Light Pollution F...
Auto-guiding setup with ASIAir equipment similar to author's goals.
Jun 5, 2025
