Best way to combine RGB and dual narrowband data
4 replies554 views
Daniele Borsari avatar
I've been shooting the California Nebula for a week and managed to capture 15 hours with the Samyang 135mm, ZWO ASI533MC Pro and Optolong L-eNhance.
I think I'll do another 1 or 2 nights to reach 25 hour-ish integration and I also think I'll shoot RGB with just a UV/IR Cut not only for the stars, but also for the background nebulosity in Taurus.
What is the best way to combine UV/IR Cut and dual narrowband data in PixInsight including both Ha, Oiii and RGB?
Daniele
Markus A. R. Langlotz avatar
Hello,
you should split  the Narrowband images inmto the 3 chaneels R,G and B, process R as Ha and (R+B)/2 as OIII.
OIII and Ha should be given the physically correct colors, as I describe here:
http://jupiter.n-t-l.de/knowledge_narrowband.htm
Into that image, you can blend in the stars from the RGB (VIS) image. An example of the cirrs nebula, I posted here lately:
https://www.astrobin.com/uzsxlb/
Markus
Christoph Nieswand avatar
Hi
If you prefer using scripts: try the NBRGBCombination Script.
The script allows to blend  R, G and B from a narrowband image into an RGB image.
I did it on fully processed NB and RGB starless images and it gave me almost the same result as blending the images in Photoshop using the lighter color mode.
The stars from the RGB are added in the end as usual.
Did not play with it very much, but maybe its worth to give it a try.
Chris
HR_Maurer avatar
Here's how i do it:
After preprocessing, in linear state, i separate the stars from the RGB image, and from the NB mono images. Then i produce NB color images using pixelmath, like
Ha: R = Ha, G = 0.001, B = 0.15*Ha
OIII: similar, but ~0.6*G, 1*B
then i do a background neutralization step, and add the NB color images. The last step would be blending the RGB stars back in.
Bringing structures from RGB in which arent present in NB requires some fiddling around, especially if you run into chrominance issues.
Add them up. And then blend the RGB stars back in. Don't forget to apply LinearFit before adding the two masters up.
Combining OSC data with dual narrowband data
I have a Zwo 533MC Pro and a L-extreme dual narrowband filter. I’m working on a project where I have about 20 hours of broadband data for M51 and 30 hours of narrowband data also for M51. I want to combine the detail and all the Ha data that I was ab...
Directly addresses combining OSC data with dual narrowband filters in PixInsight.
Jun 10, 2025
Combining dual telescope setup data for narrowband imaging efficiency (Mono Ha/OIII + OSC L-Extreme)
Good morning, For some time now, I have been experimenting with how to get the most out of my dual setup. Basically, I have the following instruments mounted in parallel on my mount, which capture the same subject synchronously: 1) A WO FLT 120 with ...
Covers dual setup with narrowband and OSC data combination techniques.
Oct 11, 2025
