I need help understanding something. I often hear experienced imagers say they want long focal length scopes to do images of DSOs. They say it "increases resolution of extended objects". I am looking at adding a focal reducer to my CDK 14 ZWO 2600 combo. Using the same sensor for both configurations. Shooting DSOs. CDK 14 REDUCED: 1717mm at f/4.8, 0.45 arc sec/pixel image scale . Compare that to the CDK at native f/7.3 at 2563 focal length, 0.3 arc sec/pixel image scale. Now, assume that you're at Sierra Remote Observatories with both configurations, and your average seeing in your images is 1.5 arc sec (i know it gets .9 arc sec or less there but that's at zenith and not all the time). So, you'd want to try to target 1/3 the seeing for your Max resolution= 0.5 arc sec/ pixel. So here are the questions: Although the f 7.2 configuration IN THEORY gives you more resolution with the same sensor, wouldn't it be true to say that the seeing , even though excellent, cannot support that additional resolution since your seeing should have a limit at 0.5 arc sec per pixel? Therefore, in the real world, not in theory, both configurations are limited by seeing at their max resolution, so the f/4.8 scope will have the same apparent resolution (to our eyes, not mathematically) in the resulting images (in reality, not theoretically) as the f7.2 scope? Therefore, the f 4.8 configuration in the field brings the same resolution as the f7.2 AND adds the additional benefit of being much faster. Obviously, this all assumes the SAME APERTURE for both scopes, just different focal lengths and f ratios. Is this correct? Lastly, while we're here… it says the dawe's limit is 0.33 arc seconds for my system on astronomy.tools. doesn't that mean that i can't achieve any higher resolution than 0.33 arc seconds, anyways?
