Claudio Boicu avatar
Hello everybody so last night i decided to shoot the Ghost Nebula and Iris Nebula in one frame wiht my redcat 51 and Asi183MC Pro. Now, i only got a little above an hour of integration time but i wanted to ask, is this wierd + artifact that i see on the star between ghost and iris gonna go away with more integration time or am i doing something wrong while processing it? i shot this target unfiltered with a new moon. ive attached the starless version of it because with stars you dont really notice it. i guess what im asking is is there a way to get rid if that in processing or am i just doing something wrong while shooting
also if it helps here is the normal picture with stars, there is also a big halo around that star aswell...
Götz Golla avatar
Hi Claudio,
how many pictures did you take before stacking ? Could it be that the halo is only in one of the images ? The lines look like not completely removed trails of planes or satellites, should become clearer by looking at the individual images before stacking
Götz
yeah i know about the lines and when im gonna get some more nights in im gonna remove them, i just ran into this problem some time ago and i thought maybe i did something wrong that time so i wanted to try again. seems like the star is emitting "too much" light, and also the star is really bloated and has a ugly star halo that if possible i want to minimize that. the star halo wouldnt be such a broblem but the thing that irritates me is that + shape. ive overstretched the image, more than i would do, just so it would be visible how big it actually is..
HR_Maurer avatar
It wont go away anymore. If you already have one hour of integration, sigma clipping wont ignore it, even if it isnt there in the next session and you use very rigorous settings..
But you could remove it smile in the starless version, without doint a lot of damage.
I wonder where it comes from. Dirt on the lens? some anisotropic atmospherical diffraction effect (this can sometimes happen from ice crystals)? Something else that didnt come to my mind?
Edit: I first noticed only the vertical part. It is also horizontal. Maybe some diffraction effect from the sensor itself?
i know it now. its not dirt on the lens or anything you said. The 183MC Pro doesnt have a IR-cut filter infront of the sensor. i asked  in the pixinsight forum about it aswell and someone pointed it out. they also linked me this for image comparison: https://www.cloudynights.com/topic/...nal-reflections-in-my-celestron-c6-sct/page-3
so yeah thats settled now
Die Launische Diva avatar
The star in question is probably T Cephei, which is very bright in the IR: https://www.astrobin.com/189410/C/#c110449
If you image without an IR-cut filter, this probably could be the reason why the specific star creates such a bright halo.
Christoph Nieswand avatar
Yes, an IR/UV cut filter will help.
You see here IR reflections from the sensor's first surface (which gives the halo) and a reflection from the sensor structure which acts as a diffraction grating (which gives the vertical and horizontal "ghost" images of the bright star). These reflection go back to your flattener or whatever ist the first optical surface in front of the sensor and from there back to the sensor.
The optical surfaces of the lenses in the telescope are usually AR-coated mainly for the visible part of the spectrum and the AR-coatings do not work as well in the IR.
Chris
Helpful Insightful Respectful
HR_Maurer avatar
Die Launische Diva:
and also, why i didnt observe this on gamma Cas with the QHY183m
Star halos projected in different directions
When using my RASA 8, I sometimes notice bright stars have a projection to one side. I thought maybe it was mirror tilt, but the projections are on opposite sides in the same photograph. For example here are stars from the left and right sides of the...
Addresses star halos and optical aberrations in imaging.
Oct 16, 2021
Issue in frames calibration?
Hi everyone, this is a long post, but it’s needed to provide proper context. Thanks in advance to anyone willing to read through it and help me figure things out! I’ve been struggling for days with what seems to be a calibration issue (or possibly a ...
Frame calibration issues may explain processing artifacts in nebula images.
Jul 8, 2025
Is this an acceptable noise level?
Hello everyone, I'm looking for a bit of advice on whether or not the level of noise I'm seeing in my images is too much or not. I've recently been going after IC-63 (Ghost of Cassiopeia) and I've tried to push on the Hydrogen-alpha i...
Noise level assessment relevant to evaluating image quality and artifacts.
Apr 12, 2025
M51: Ideas for the fuzziness
Hello everyone, I need some help/tips/critiques to understand an issue that i see with the following image of M51: https://app.astrobin.com/i/aiuc5p The data is from a Seestar S50, 310 x 10 s subs from Bortle 4-5 skies. My Pixinsight processing workf...
Similar nebula imaging artifact troubleshooting with integration time considerations.
Mar 7, 2025
