willner1227 avatar
Hello,
First time posting for guidance here, thanks in advance. I tried imaging a wide field with my 85mm Sigma Art lens and my ASI294MC Pro. In the image below, there is a section with what appear to be saturated pixels? Blue and red pixels. While the whole image seems to have evidence of the issue, it's especially pronounced in the one area. Has anyone encountered this before? I'm thinking my subs were too long. I did 3min subs and calibrated with dark and flat frames. Does anyone know any good processing techniques to repair these pixels using reasonable neighboring pixels or what I may have done wrong during acquisition?
They are NOT saturated pixel. You just had condensation on the sensor (been there) and, alas, there is no saving from it. You might want to check whether some of the single frames are not affect or affected the least and use only those instead. Forlorn hope, I know…
Insightful Respectful Concise
Fabio Guerceri avatar
I confirm, is a dew problem on the sensor of ASI294. My solution is dry/sobstitute the desiccant tablet inside the camera; or if the desiccant is ok, try to go down the temperature slowly and don't too much cold. In the summer when the envirolment temperature for me is around 30°-32°, i go down step by step of 5° and i stop on -5° not over.
During the shooting session if you view this effect, you can return the camera temperature up to 5-10° and when the effect disapear, go down slowly and stop it before the previous temperature.
bye
willner1227 avatar
Thanks for the help.  I will change the desiccant and adjust my cooling practices.  This is how you learn I guess.
red blotchy background with asi294mc pro
hi everyone! I recently got my first Astro dedicated camera, the asi294mc pro, and I've been having issues with a red blotchy background in all of my pictures, they all have the same pattern and only show in the red channel. I've seen in othe...
Same camera model; likely discusses similar sensor or color issues.
Apr 23, 2022
Seastar New 2.5 Firmware Update Has Brought New Changes and Problems?
Hello and welcome. I'd like to state some information and ask every seastar user who has noticed the minor firmware update of the seastar. Itt turns out ZWo has changed a bit the EQ mode now after setting the seastar current altitude we have a ne...
Irrelevant - discusses Seastar firmware, not imaging artifacts.
May 25, 2025
Looking for advice on image processing
The following image was about 3 1/2 hrs of data on the Crescent nebula. I know the stars are bloated, it's noisy and the colours don't seem right, so just wondering what any of you would do if you saw this kind of result (apart from cry). Cle...
Pixel saturation and image processing issues relevant to nebula imaging results.
Dec 9, 2021
First look. Nightfall Astro Sigma Art 85mm rings
Hi all, A quick post about something new. Nightfall Astro rings for the sigma art 85mm. i think I was the first set they shipped globally. So I thought I’d post a first impression. As virtually nobody else will have seen these. firstly these were pai...
Irrelevant - product review of lens rings, not troubleshooting.
Feb 8, 2025
Should I bin 2X2 or higher when shooting?
I am shooting with a ZWO-ASI585 MC PRO coupled with the Rokinon/Samyang 135mm F2 Lens. I am Undersampled right now with a res of 4.43"/pixel. I am new and have gotten pretty comfortable with my setup and what to start exploring ways pull more de...
Relevant - discusses binning with ASI camera; relates to exposure optimization.
Feb 7, 2025
