telescope speed ... F4.0 vs F5.6 ..twice as fast for double the price ?
Sean McdvbArun HDan H. M.SemiPro
48 replies2.7k views
Tobby avatar
reducers are highly advertised to help increase the speed of a scope.
generically, lower F = higher "speed", however I could NOT find an article easily quantifying what "faster" means, without complicated formulas.
I eventually came across this link:
https://scantips.com/lights/exposurecalc.html
I specifically looked to compare 2 telescopes I have on my "radar" to purchase: Askar FRA400 and FRA500.
FRA400 (no-reducer): focal length 400 and F5.6
FRA500 (no-reducer): focal length 500 and F5.6
FRA500 (with-reducer): focal length ~350 and F3.9
according to calculator from above link, 4.0 needs half the time (64s) to collect as much light as 5.6 (128s)
making FRA500 with reducer very similar with FRA400 but twice as fast (!! yuhuu)... for almost double the price (huuuu ( )
below calculator and also FOV for comparison.
are my calculations wrong ?
has anyone else done similar calculations for other scopes ?
anyone else has found a better cost / speed ratio for a different scope ? with similar focal length ..
i
SemiPro avatar
We are in the signal-to-noise ratio business here, and one of the more useful calculators that I have found for comparing systems is this website: https://lambermont.dyndns.org/astro/code/compare-telescopes.html
With the same camera, 124 seconds on the slower system is about 62.7 seconds on the faster system.
wizzlebippi avatar
Having spent a long time researching this, there's a lot of bad information out there based on how camera lenses work.  You can't blindly apply the same logic as a camera lens because adjusting the f stop means adjusting aperture.  The focal length of the lens is unchanged, and the native focal ratio is unchanged, therefore the field of view is unchanged.  Telescopes do not work this way unless you're using an aperture mask.
Focal ratio is a bad means of comparison between scopes, so don't use it.  In fact, there's not really any one parameter that's a useful means of comparison.  You have to think about it as a system, including your camera and any focal reducer you might use.  The best means of comparison I've come up with is aperture per pixel.
First and foremost, aperture wins.  More aperture means finer details.  More aperture means more light enters the scope, meaning more light can reach the sensor.  Focal reducers factor into this by shrinking the image circle to fit smaller sensors or sacrificing resolution and expanding the FOV for larger sensors.  Using the FRA500 as an example, natively it has a 55mm image circle, comfortably illuminating a full frame sensor.  With the 0.7x reducer, mathematically the image circle shrinks to 38.5mm (55*0.7).  Based on the spot diagrams, the scope still accommodates a full frame sensor, though there may be some vignetting, or the native illuminated circle is wider than 55mm (wider than the corrected image circle) to avoid this.  Assuming a constant pixel size, the 0.7x reducer increases the amount of light hitting each pixel by 1.43x, meaning you would be able to image considerably faster with the reducer.  The cost is a loss of resolution, the logical tradeoff of a larger FOV.  More importantly, the reducer can't change the physics of the scope its attached to.  The FRA500 still has a 90mm aperture and is f/5.6.  When considering a reducer in a comparison, I find it more useful to divide the sensor diagonal by the reduction factor (effective sensor size) instead of changing focal length.
An interesting thought experiment along these lines is considering the ZWO ASI2400MC Pro (Full Frame) and ASI2600MC Pro (APS-C).  If you put the ASI2600MC Pro behind a 0.65x reducer, it has a similar FOV and resolution as the ASI2400MC Pro on the same scope natively.  Therefore, despite the significantly faster effective focal ratio of the scope with the 0.65x reducer, both cameras will capture roughly the same image in the same amount of time.
Ultimately, it's a question of what are you hoping to image.  If it fits in the FOV, there's no point in going faster because you're already capturing all the light it's emitting.  Telescopius and the Field of View Calculator are your friends.  Beyond that, I recommend that you buy the largest scope you are willing to deal with that meets your requirements.
Helpful Insightful
Sean Mc avatar
Don’t forget image scale.
if I want to capture m33 for example, a 700mm f7 scope will be faster than an 135mm f2.
John Hayes avatar
If you match the sensor to the telescope for equal sampling in object space, the only thing a reducer does for you is to increase the field of view.  If you hold the pixel size constant (as you do in a standard camera), increasing the optical speed (by decreasing the focal ratio) increases the signal by the square of the ratio of the focal ratios.  Here's a formula that I posted a number of years on CN that explains it (F1 and F2 are the focal ratios of the two telescopes).  I believe that this is what the Compare-Telescopes site is computing.
Helpful Insightful Respectful
Joe Linington avatar
The Askar 400 is a 72mm scope at a native 5.6, the 500 is about 90mm at the same native f-ratio. There are tons of less expensive options depending on what FOV you want, some are even petzvals but many are either triplets or doublets. I would look at the rest of the Askar/SharpStar lineup. There are some great deals in there like the 76EDPH, 80PHQ, 103APO, ASKAR-V, 94EDPH that are all less expensive than the Askar 500 and reducer. You can also look at the Astro-Tech EDT and EDP lineup and SVBony SV550. Everything I have listed is a triplet or better but to save even more money, the Astro-Tech ED and EDL lineup and the SVBony 503 are also available. If speed is your thing then an f/4 newt with a starizona 0.75 reducer, SharpStar f/2.8 hyperbolic newt or a RASA or Hyperstar are all options.
If I was in the market now the Askar 103APO would be high on my list but the Askar V is very compelling too.
SemiPro avatar
John Hayes:
Yes, the Compare-Telescopes site does a similar thing. Going off an old thread where you used your equation, I plugged in those same variables to the Compare-Telescopes site and it spat out the same solutions.
To the other folks posting in this thread, its important to understand what aperture helps you with in long exposure, deep space astrophotography. More aperture means a longer focal length at a respectable focal ratio, which allows you to use cameras with bigger pixels while still maintaining a good image resolution. If you used the same camera on a small telescope at F/4 and a much larger telescope at F/8, the F/4 telescope wins in building signal but not in resolution. However, if your telescope is big enough, you can beat the F/4 telescope both in building signal AND resolution if you use larger pixels in your camera.
Just saying "go and buy the biggest telescope you can afford" is not super helpful advice in my opinion. There are a lot of factors at play, some of which cannot be helped by a huge mirror or lens.
dkamen avatar
The calculator you are using is a for a camera lens. It makes the assumption that when f/number changes, aperture changes but focal length and image scale remain the same. This is not what is happening with a reducer. The reducer changes image scale, while aperture and focal length remain the same. So you are collecting more light per pixel but also smaller resolution. For the central part of the image (the one that fits in the frame both with and without reducer), using a 0.65X reducer is exactly the same as capturing natively and then scaling at 65%. What the reducer really gives you is a wider field (useful if your sensor is smaller than the native image circle) and better sampling (useful if your pixels are too small for your native focal length, not really an issue below 700mm).
Dan H. M. avatar
Interesting tool. I’m a little confused by “object signal.”  What’s the difference between this and etendue?
Sean Mc avatar
Isn’t poi the number that you’re concerned about?
dvb avatar
Filter economics may also be a consideration.  The faster f/ratio will result in a steeper light cone & shifting of the band pass, whether the result of native focal length or a focal reducer.  That may mean purchase of f3 shifted narrow band filters.  The steeper light cone may also make a larger filter diameter desirable to reduce vignetting.
Helpful Insightful
Sean Mc avatar
Object SignalObject Signal is based on the Etendue of an extended object that fits in the FOV of both scopes, corrected for the sensor Quantum Efficiency and total optical system Transmittance losses.
Perhaps this is the metric that fits best.
so the comparison between the two scopes listed by the OP shows that the fra500 with reducer is 40% faster ON THE SAME OBJECT than the fra400 native, not twice as fast because the reducer changed the focal length.
Sean Mc avatar
[pre]
 [/pre]Telescope 1 f/ 3.90 fl= 350mm D= 90mm O= 0% res=2.24"/p FOV=37.3'x37.3'=34.31x eoi= 6.57x poi= 1.26x e= 6.57x pe= 6.57x ps= 6.57x os= 0.19x #
Telescope 2 f/10.00 fl=2050mm D=205mm O= 0% res=0.38"/p FOV= 6.4'x 6.4'= 0.03x eoi= 0.15x poi= 0.79x e= 0.15x pe= 0.15x ps= 0.15x os= 5.22x
and for example, a c8 at native f10 images an object 5x as fast as a 350mm f4
SemiPro avatar
From the website:
"Object Signal is based on the Etendue of an extended object that fits in the FOV of both scopes, corrected for the sensor Quantum Efficiency and total optical system Transmittance losses."
Formula: object_signal = aperture_area [m^2] * QE-factor * Transmittance_factor
So it makes sense that the bigger telescope would win in this case.
Sean Mc:
No not really, deep space objects are extended sources, while stars are point sources. Though, it does not change that the bigger your objective, the finer your stars are going to be resolved.
Sean Mc:
The metric that fits best is pixel signal, because when it is all said and done, at the end of the day we care about how much signal our pixels are actually collecting. Of course you need to balance this with the image resolution and what kind of FoV  you want, but if we are comparing how "fast" two systems are then pixel signal is what we want. Again, the reason why bigger telescopes can be better is because they allow you to use larger pixels while still having a good image scale.  The formula for pixel signal does take into account the aperture as well.
Sean Mc avatar
Pixel signal will always favor a wider fov. I don’t think it’s a metric that can be used to compare two different fov’s. it’s the same as comparing focal ratio and ignoring aperture.
Anderl avatar
The faster the f ratio the more light will hit your sensor. Imaging with my 105 1.4 lens and an full frame z6 i am overexposed at only over an minute of exposure time.
aperture is one thing that contributes to the f ratio, f ratio is focal length / aperture.
That means that more aperture allows you to image at longer focal lengths while still maintaining a fast f ratio.
An often overlooked thing is sensor size (i don’t think that pixel size plays that big of a role, maybe a little but mostly in terms of resolution).
The bigger the sensor the more light you can capture. An imx411 sensor will allow you to capture over 5.1 times the light of an apsc sized sensor at least if you have a scope that has an big enough image circle.
In short
= more aperture = more photons per arc second
= faster f ratio = more photons in general
which is better totally depends on your goals.
cs
andi
Dan H. M. avatar
From the website:
I think I'm still confused.  Isn't this just comparing FOV?  A given object will generally fit in the FOV of two systems of comparable focal lengths.  Exceptions would be for very large objects, but this doesn't really seem to have anything to do with exposure.  The faster, smaller aperture system just captures the target faster because the slower, larger aperture system would need multiple nights mosaicing to get the full field.
In the below comparison, I've put in the values for my Rokinon 135 lens and Takahashi Epsilon 130D.  The Epsilon blows the lens out of the water in "object signal."  For the others the Rokinon is generally ahead.  This leads me to think I'm much worse off going after most extended objects with the Rokinon than with the Epsilon, despite the Rokinon being f/2.  The Rokinon is really just for those huge objects that I don't want to sit around mosaicing.  Am I missing something?
SemiPro avatar
From the website:
It all comes down to what you want to sacrifice in one area to gain in another. For instance, lets say you want to image Andromeda. Yes, you can build a better SNR faster with the Rokinon, but the detail will not be there because of the pixel scale. If you shoot it with the Tak 130D, then you get the detail but now you are not building SNR at the same rate.
Now lets see what happens if I try to have my cake and eat it too; what if I used the 294MM on the Rokinon in bin1 mode and then drizzled it? I get to the pixel scale of the Tak, but now the F/2 scope actually builds signal slower than the F/3.3 telescope.
I said above we are in the SNR gathering business, but I should temper my statement with SNR is not everything. I mean I can build a tonne of SNR with a Rokinon 135, but who is to say it will look good? There could be tilt, chromatic aberrations and astigmatism. The pixel scale will leave out fine details. Yeah it might take longer with the Tak, but I would bet the image would be better.
Personally, I use this tool to compare different systems to see how long it would take me to build a comparable SNR between them. For example, I have used the FLT91 and Redcat51 enough to know that it takes X number of hours to build a good SNR, and by using this calculator I can figure out how long a comparable SNR would take on another system, such as my RASA8 or RC8.
I think the major takeaway is knowing what it is that makes a system fast or slow, and this is what the calculator can show you. It shows you that it is a combination of many things. It's not just aperture, and its not just focal ratio. You gotta add in quantum efficiency, the pixel size, and the transmittance factor if you know it. Things change if you are comparing a system using the same camera or not. Are you binning? Do you plan on drizzling? All things to consider.
Helpful Insightful Engaging
Tobby avatar
thanks @SemiPro for the advice and details...
while this thread was evolving, in another place I found a simplified formula, similar with what was put above by @John Hayes : (F2*F2) / (F1*F1).
how did you compute the 62.7s for the faster scope ? .. maybe I interpret the numbers wrongly, but I get 60.7s
I must admit, I understood maybe less than half of what has been discussed in this tread. topic is more complex than I originally thought
to give a better idea of why I'm looking at the speed:
I'm going to image in light polluted city with Bortle 9 skies.. and without an opportunity to drive to the country side to better skies. Singapore is a small country/city.
even so .. I will still need to drive out to a park or area where I'm not blocked by city building.. but I'll still be with a lot of light pollution.
because of the light pollution, I will need significant more imaging time to get decent imaging. this I've learned and got my inspiration after reading Lee Pullen blog on https://urbanastrophotography.com/
I will need to be mobile and make the most of my nights out sessions with the constraints of the place I'm in.
in a nutshell:
- a faster setup/system that will reduce the imaging time, is appealing. .. and why I started to study the topic.
- setup/system can not be big either.. so it's easy to transport and setUp.
- price is also a constraint,.. as budget is NOT unlimited.
400-500mm focal length is more than enough for a portable setUp.
Dan H. M. avatar
@SemiPro Your explanation makes sense.  I'm still unsure what "object signal" means but the other indicators make sense.  I probably should go through some of my data and see how it looks un-drizzled since I always drizzle and am sometimes disappointed at the SNR.
@Tobby I image in B8 skies so I feel your pain.  For an excellent portable setup that doesn't break the bank and is usable under bad skies, it's hard to beat a Rokinon 135, even if you have to step it down a bit to use it with a narrowband filter.  It depends on what kinds of objects you really want to get though.  For smaller nebulae its use is limited.  For large nebulae, it's excellent.
Arun H avatar
A simple way I look at this is the following.
The light entering your scope does not know (or care) what size pixels, sensor etc. you have. In object space, meaning for a given square arc second of object in the sky, the SNR is therefore determined purely by aperture and integration time (ignoring things like light pollution). Games we play, like the use of reducers, pixel size of cameras, size of sensors, etc., simple serve to change how that light is concentrated or the field of view actually captured
If you take two systems, of different f ratios but which both capture the FOV of interest, the system with the larger aperture will always provide the better SNR regardless of focal ratio when the images are presented at the same viewing scale. The most important question to ask is "will what I want to image fit in the FOV of X system"? Within this constraint, a larger aperture will always give you the better result.
Sean Mc avatar
Yeah I wish I’d understood this before purchasing scopes.
Dan H. M. avatar
Arun H:
This makes sense.  So perhaps it should say "fill the FOV" rather than "fit in the FOV."  But where does "signal" come in?  Say I'm going to a dark site and want to capture a given object in one night and I don't care much about the amount of detail in it.  For argument's sake, let's also say I don't care about the FOV.  Do I take the instrument with the lower f-ratio?  Or is "signal" just referring to the amount of detail in the image and not the amount of time it takes for the object itself to show up in the image?
Sean Mc avatar
Tldr: aperture=speed.
The focal ratio just determines fov. In photography we talk about f/stop being speed. Think about it for a sec. In photography we are changing the aperture inside the lens. Bigger aperture = more speed. In photography we are not changing the focal length. When using a telescope, we typically DON’T change the aperture, we change the focal length (fov). Focal reatio (f-stop) can only be compared directly if you are comparing the same focal length.
Aperture also=detail for the same scope design.
I.E. a 6” f8 refractor will give slightly better contrast than a 6” newt or sct.  But a 6” refractor or newt will give better detail than a 4” refractor.
Arun H avatar
The differences between terrestrial and astro photography are not as different as one would imagine. Both are governed by the same laws of optics and the inverse square law.
A 35 mm f/2 lens and a 200 mm f/2 lens would yield the same scene exposure and concentration of light on the sensor, but the way they achieve that is different. The 35mm f/2 is capturing light from a vastly greater area. But if you take a crop from the 35  mm f/2 lens that is similar to the FOV of the 200 mm f/2 and blow it up to the same size, the loss in SNR will be obvious. The 200 mm f/2 will give the cleaner image. You can correct this, of course, by moving significantly closer to the object  with the 35 mm f/2 (and ignoring the distorted perspective), but that's a luxury you don't have in astrophotography. The distance is always infinity. So the primary benefit of focal length is field of view.
If you are simply concerned about coming back with great data, pick the fastest lens/scope and then pick an object that comes close to filling the field. If you have a specific object in mind, pick the largest aperture that will give you the FOV of that object with your chosen camera. These are two different situations.
Is there a way to calculate the needed exposure time at a given f-ratio at which more data will not lead to a better picture anymore?
is there any way i can calculate or at least come close to the needed total exposure time under a given f-ratio and bortle scale at which i won’t get a better image if i image any longer? I also want to bring another question as well. is there a poin...
Directly compares telescope speed (F-ratio) performance and cost-benefit analysis.
Mar 23, 2022
Fast Scope vs Large Aperture
I tried to get some feedback on another forum but it was crickets so I am going to try here where there is good conversation. So I have literally spent hours reading about this the last few days. I am not nearly as smart as many of the people in this...
Directly addresses comparison of fast scopes versus aperture trade-offs.
Feb 20, 2025
