What is wrong with my optical train?
11 replies619 views
Arny avatar
I am going crazy over trying to get Jupiter in a decent image and went through a steep learning curve of using a totally different approach than for DSO.
So I have
- using UVIR filters,
- checked collimation of the EdgeHD scope
- upgraded to an ADC
- got a Baader steel focuser
- got a dedicated planetary camera
- been  being patient to wait for good seeing.
This all helped improve my efforts and results have slighty improved - but I still don't get these crisp sharp images of Jupiter - and now I ended up with Croissant like shapes of the moons and its shadows (magnified section of the image https://www.astrobin.com/4q1vxf/)
=> Any idea, where I need to dig deeper in my image train to track down this fault?
Alan Hancox avatar
Recheck your collimation. It's very critical to a sharp image but even if it's ok your at the mercy of the weather. Try and image on only the steadiest nights.
Concise
Why are you using an ADC? Are you imaging that low on the horizon? It is worth the while if it is 35deg and lower otherwise it is more likely you harm your results than anything. And frankly the chance of getting good seeing that low are vanishingly small. And collimation; it must be done in focus with an EP at high magnification.If you can't see the Airy disk, even if only at times, then ain't worth imaging Jupiter.
Patrick Graham avatar
I'm not that experienced in planetary imaging but I took a seminar on that a few years ago and here's what I remember:  Take several minutes of video; this will allow you to select the best frames as seeing changes constantly when imaging planets.   When you have your best frames selected, use Autostakkert or Sharpcap to process your images. It's in the processing that you can bring out the sharpness and detail of Jupiter and Saturn.   Also,  I believe Adam Block has a series of tutorials on planetary imaging that are very useful.  Hope this helps.
Patrick
Arny avatar
I tried with and without ADC - no difference.
(I dis get it in the first place, as at 52N many things are low - but I try to shoot only if higher than 30 degrees )))
But could that explain croissant like moon shapes?!
Arny avatar
Alan Hancox:
maybe I have never had good seeing yet - but last days have been pretty good, and ai die notice improvements in quality.
but could seeing or collimation shape rhe moons into croissants?!
Arny:
It could, if improperly set up. Or your scope is massively out of collimation. Or both. I'm slightly north of you (53.2N) and I'm pretty sure that the time of imaging Jupiter is pretty much past this season. Besides, It has been cloudy for the past four weeks...
Oskari Nikkinen avatar
Your odd looking moons suggest you are not in fact well collimated because even in bad seeing they should be round and not crooked like here. Id say there is a fair chance you are way off ideal collimation.
Just so you know an ADC is not strictly necessary for sharp planetary images at 30 degrees of elevation, like pictured below from one of my last years images taken with an 8'' f/4.4 newtonian barlowed to around f/12 if i recall correctly (and an ASI678MC). Taken in september 2022 from 60N when Jupiter was right around 30 degrees in elevation, and no ADC was used. Although an ADC would certainly have improved the image at this elevation i think you will still agree that the lack of an ADC is not holding back the image too much to be any kind of main concern.
But also just want to point out that nights with clarity like the above image are very rare with the results with my scope usually looking something like below, which was imaged on september of this year with a much better elevation of above 40 degrees. Still softer because seeing was not so good this time.
So everything could be right, but the skies will just not give, but i think your setup has some work to do.
I'd say look into collimation once more, and this time maybe do that with the planetary imaging train itself on a slightly defocused star.
Arny avatar
Arny:
Thanks, Andrea - your experience and your great planetary images speak for the fact its not my lattitude :-)
As there is consent in the comments on my collimation being the reason I‘ll tackle this. In fact I have checked out of focus only - will try in focus with high power piece. Thanks!
But when you say Jupiter season is over, I was surprised to hear, as according to Stellarium it will keep rising up to 50 degrees and actually earlier each night until december. Or am I mistaken?
Arny avatar
Arny:
Thanks, Andrea - your experience underlined by your great planetary images speak for the fact its lot my lattitude :-)
But when you say Jupiter season is over, ai was surprised, as it will keep rising higher and earlier each night until
Arny:
That's true but has we head into the fall/winter months the prospects of good seeing with fair transparency are quite small where I am.
Leah Deckard Hallett avatar
Better your latitude than your attitude smile
Leah
Greetings from Bouchemaine, France
Shame on me : I begun posting here before having presenting myself ! I have to thank all this great community : I am learning and it is very, very, helpful to look at the wonders that are posted here. Seeing what can be done, what I like and what I l...
Optical train troubleshooting relevant to planetary imaging with ASI533.
Feb 19, 2022
