Skywatcher 0.9x coma corrector
3 replies216 views
Alan Hancox avatar
Hello
Just a quick question. I`m using a 150 PDS (FL 750 mm). According to my calculations using this corrector should come out at 675 mm. I took an image and it plate solved at 698 mm. Does this mean the spacing is too close or too far away from the sensor?
Any help appreciated.
Alan
Lee avatar
Alan Hancox:
Hello
Alan
Hi Alan, it probably still means you're suffering a hang over from your previous issues/queries around the spacing.  The backspace is fixed at 55mm + filters, there's no getting away from that and I don't think anything should correctly be pushing the plate solve it to 698mm except the aforementioned "issue" which caused you to run out of in focus.
My 0.9x + 150PDS plate solves to 678 or 679.
Apologies, I don't have a reason for this except I'm fairly certain it's related to your first issue from last week.
It could be either way or none at all. The focal length reduction factor isn't necessarily a constant across the board of focal ratios. Neither is a constant across different specimens, so in your case is 0.93x against the advertised 0.9x. Assuming that the original focal length was 750mm, which isn't a given. Have you measured it (the original focal length)?
Alan Hancox avatar
Actually no i haven`t. I think i need to check that out…..
Problem ZWO ASI 662 and SW 150/750
Hi everyone. I'm new to this, and yesterday was the first time I tried attaching the camera to the telescope. I have the Skywatcher Newton 150/750 PDS and the ZWO ASI662 camera. When I tried it with the camera and its original head, I was able to...
Discusses same telescope model (SW 150/750) and potential spacing/attachment issues.
Jul 26, 2025
Anyone using this with a 120mm f/7.5 OTA?
I can't figure out what the adjustment value for this focal length should be. The OTA I'm using this on is a Sky-Watcher Equinox 120ED Pro f/7.5, with a 900mm focal length. This is the list that Teleskop Service provides with the required, bu...
Similar focal length adjustment and corrector spacing calculation problem.
May 26, 2025
