What sequence to follow for setting up ?
5 replies315 views
Eric Gagne avatar
Hello,
I invested in some equipment to improve my astrophotography and I might have taken a byte bigger than I can chew.  I got a Goto mount, an ASIAIR plus, ZWO EAF, ZWO Guide camera and scope and now that I’m looking at it I am not sure what would be the best sequence to follow.
I think I have to do all the following but not sure if I got it in the right order.   How do experienced astrophotographers do it ?
Rough focusing of guide scope and camera
Polar alignement
Start tracking (if it doesn’t start automatically)
Slew to a bright star
Focus guide scope
Focus camera with EAF
Slew to home position then to target
Start EAF (is this actually a step or does it start automatically when powered)
Start guiding (same question as above)
Configure autorun, start it and let it do its magic all night.
I don’t know if it matters but I am shooting with a DSLR and a Samyang 135mm.  Sorry for asking such a basic question, I should have taken the time to learn a bit but shopping for AP equipment is so fun I got a little carried away,
Quinn Groessl avatar
That’s more or less the order I do things. My rig never comes apart really, so I can skip the rough focus. I use the ASIAIR as well.
polar align, go to home, slew to target (it should start tracking on its own here), then calibrate and start guiding, EAF on the filter I plan on starting with, then set up my auto run or plan, push go.
I don’t think I’m forgetting anything.
deleted avatar
Bonjour du Nouveau Brunswick.
Pour répondre à ta question, voici ma séquence, à noter que j'ai un observatoire permanent, donc ma séquence sera un peu différente de la tienne:
  • Installation du télescope et de la caméra.
  • Balancement ou équibrage de la monture en m'assurant que le poids est bien réparti sur les deux côtés, ainsi que vers le haut et bas, donc en AZ et en DEC.
  • Allumer la caméra et partir le refroidissement.
  • Faire les "flats" et mes "Dark-for-flats" pendant que je fais autre chose.
  • Mettre la monture au point de départ (position zéro).
  • Faire la connexion avec la monture.
  • Choisir une étoile brillante dans la région ou je planifie de faire mes images, y envoyer ma monture - je me sers de NINA, je 'ai donc pas besoin de faire l'alignement de la monture. NINA le fait par "plate solving".
  • Une fois centré sur l'étoile, faire la mise au point du télescope, soit manuellement avec un Bahtinov, ou automatiquement avec un focuseur électronique.
  • Une fois ma mise au point faite, Je fais la mise au point de mon télescope de guidage.
  • Laisser mon autoguideur faire sa calibration.
  • Partir Stellarium, sélectionner mon objet et transférer les coordonnées à NINA.
Je suis prêt pour ma session. Ma séquence est déja pré-programmée dans NINA, je n'ai qu'a la partir.
A noter que je n'ai pas besoin de faire mon alignment polaire à toutes les fois, vu que je suis sur un pillier. Je ne le fais q'une fois aux six mois.
Au plaisir.
Sean Mc avatar
I’ll add a few things that make each time easier.
i put patio bricks in my lawn under the tripod legs after i found out where i wanted the scope and found polar alignment. I then drilled a small divit for where each tripod leg spike goes. Makes the job of setup way way easier.
make sure your tripod is level, or guiding will go to crap.  The patio bricks help with that.  I don’t change the length of the tripod legs when i take it in the house so everything stays level for the next time.
you probably won’t need to change your guide scope focus after the first time.
eaf and guiding start automatically if you “plan” your imaging session.
Baronvonsmoogle avatar
It is pretty much the way you do it except I don't take apart my guidescope/camera so they very rarely need to be refocused.
Tips on setting up an Off Axis Guider (OAG)
Here is a guide with some tips on setting up an Off Axis Guider (OAG). I find these significantly improve of your tracking and image quality. I hope this is helpful as I feel some beginners may be a bit intimated by a OAG. Link:https://astrogeartoday...
Beginner seeking equipment setup guidance; OAG guide addresses setup concerns.
Mar 2, 2022
Starting to imaging deep space! (Northwest spain)
Hi to everyone, my name is Toni and I am starting to shoot deep space objects with a cheap mount, a cheap lens and my expensive mirrorless ^_^. I will try to improve my equipment to achieve great shoots soon. Thanks to everyone and clear skies!
Equipment setup sequence guidance helpful for improving current cheap setup.
Apr 14, 2022
How to end overnight session
Hi! I am wondering what people do at the end of an overnight imaging session. Does it matter if the scope just stops or do you let it slew back into home position? I am using the Asiair and had some power troubles. Using a poor power cable, the Asiai...
Relevant for understanding complete imaging session workflow and shutdown procedures.
Feb 22, 2025
Considering a Guide Scope - Never used one
I am very new to astronomy and astrophotography. For just over a year, I have been trying my hand at this astrophotography "hobby". Getting sucked deeper and deeper into this ever-growing desire to get better and it is rapidly developing in...
Relevant as author has guide scope/camera and needs setup sequencing guidance.
Apr 16, 2025
Solve & Sync
I am getting advice to delete Solve & Sync from the NINA advanced sequence because I have already built a 99 star model using 10Micron Tools. I am imaging unguided and getting excellent results. Should I follow this advice? Is the model itself al...
Relevant for understanding plate solving in automated imaging sequences with ASIAIR.
Jun 15, 2025
