Backfocus issue : Canon Lens With ZWO 2" EFW and ZWO Asi 183
2 replies100 views
tazdevil71 avatar
Hello guys, I plan to use a Canon Lens with my cameras and A 2" EFW
I have 2 cameras : 2600MM and 183 MM.
I do not find issues for the 2600 : My lens + EOS lens adapter for 2″ Filter wheel + 2"EFW + ASI 2600 without tilt Ring –> it seems to be OK for 44mm back focus
But For The 183, i'm stuck : Lens + EOS lens adapter for 2″ Filter wheel + ASI 183 seems to be the solution, but i 've 2 issues :
- How can i mount the Asi 183 on the 2" Filter Wheel (M54 thread)
- If my calculations are good, i need to add 6mm more of Backfocus to achieve the 44mm. Am i right ? and then which ring must i add for those 6mm.
Thank you so much for helping.
Get a M42 to M54 adapter and then add spacers as required.
tazdevil71 avatar
thank you 👍
was not sure that the 183 thread was a M42 one.
perfect
Connecting ASI2600MM Duo to Sigma (Nikon) Lens
I want to image wide angle areas of the sky, and for that I am using a Sigma lens with an astro camera, but I can’t obtain the focus. I have tried different backfocus distances, see below, but I’m unable to get anything close to focus. Does anyone ha...
ASI2600MM lens adapter and focus issues with Canon lenses similar.
Mar 29, 2025
How do I know if my backfocus distance is right?
I've just found out that with a field flattener/reducer the spacing between it and the camera is important. I thought that as long as you can achieve focus (I can) then it was all ok. But it seems not. So, how would I tell if my spacing is wrong?...
Discusses backfocus spacing issues with camera and optical equipment configuration.
Jan 29, 2022
Samyang 135 f2.0 canon mount rotator solution
Hi friends. I have a great setup with samyang 135 f2.0 umc (canon) with my 2600 mcpro and 2600mmpro + efw filter wheel. I have some angle rotators here but the distance increase 44 mm if i use it so i can´t focus. Any solution that you know to use ro...
Canon lens with ASI2600 and EFW filter wheel setup experience.
Feb 16, 2025
ASI183mc pro or ASI533mc Pro with Redcat51
Hello all! I've done a bit of research on it but I feel it's going to be easier to ask straight out. I'm currently using a stock Canon 600d with a WO Redcat51 on star adventure pro 2i, I plan on staying with the Redcat for a while but, I ...
ZWO ASI 183 camera paired with equipment; directly addresses your camera choice question.
Dec 1, 2021
Astigmatism with 50mm focal lens in conjunction with astronomy cooled camera (yet not with a DSLR)
Dear AB Friends, during a backfocus tuning session for a new Sigma 50mm 1.4 Art lens, I found out that when it was used together with a cooled astro camera (I used a Touptek 2600 Color), it generated visible astigmatism in the corners (Picture 1). Th...
Canon lens with ASI cooled camera backfocus and mounting concerns.
May 24, 2025
