ASI Air Mini just steers into the completely wrong direction
16 replies679 views
Jens avatar
So I just recently got the ASI Air mini. my Gear: SA GTI, modified canon eos 600D, zenithstar 61, zwo mini guidescope and mini guide camera.
I wanted to photograph the soul nebula and told the asi air how to frame it with the sky atlas. at first it platesolved, went into the right direction and was pretty close, platesolved again to check if it's framed right, and then went into the complete wrong direction and slewed the whole telescope into the wrong part of the sky.
I have no idea why it would do that since the first try was super close.
I made sure that my location Coordinates were perfectly right, (even though I can't use my gps on my phone (Error 4) I have to search for it manually) and I set my phone to the right time without daylight savings.
The asi air had Platesolved wrongly once or twice and got confused where it was but I don't think that was the issue because the issue came up literally every time I tried aming the Telescope.
I can't currently find any other point of failure on the asi air. do you guys have any suggestions?
John Richards avatar
Please look at this thread on the ZWO forum.  It seems other folks have had this issue.  You may need a firmware update on your mount.
https://bbs.astronomy-imaging-camera.com/d/15229-asiair-star-adventurer-gti-problems
Hope this helps
Supportive
Jens avatar
Awesome!! thank you so much for this link, that sounds exactly like my problem. I hope that will work for me smile
Sean Mc avatar
If it happens after all the suggestions above, change out the USB cable.
V avatar
I found the problem to be camera orientation. On non-astrocams the mini thinks that the camera is upside down, so you have to orient the camera upside down for platesolve to work properly, otherwise it will slew upside down.
Jens avatar
Do you think the mini uses the gyroscope to figure out orientation? Doesn't it just look at a single frame to determine it's orientation?
V avatar
Jens:
No. The mini uses platesolving, but for some DSLR's and Mirrorless cameras (like my A7III) it vertically flips the image, which causes it to platesolve upside down. I suspect it associates that with the mount being upside down rather than the camera sensor.
Mark Hindman avatar
Well, I once installed my guide cam upside down… got some strange results.  ;-)
kurt ragsdale avatar
I've tried twice with my new skywatcher 35 mount and it's gone in the wrong direction both times even though last night I polar aligned it and I think I have all my information in there right. It might take a few more attempts to get in the ball park but I don't know. It's also telling me Jupiter is below the horizon when it isn't.
Jens avatar
So I tried pretty much everything you guys recommended.
I updated the mount and reinstalled the firmware on the asi air.
I turned the camera upside down since it's action does imply that this is the case but I took the guide cam as main camera as a test and the issue was still the same.
I changed the time of my phone to different times and nothing changed either.
I noticed that it seems like the Mount has different coordinates baked in. The mount seems to have different coordinates than the sky atlas of the Asi air.
whenever I want to point at, let's say andromeda, I frame it up in the sky atlas, it slews over and it just points right next to the andromeda Galaxy in it's first slew.
It platesolves to check if it's framed up correctly and then goes completely off the rails and goes into the complete Opposite direction than it is supposed to.
the Asi does work if I steer it manually. as soon as it's on the target it works. But that's not why I bought the asi air.
I'm really running out of ideas on what this could be.
Sean Mc avatar
Try a different usb cable?  I don’t seem to have a problem with mine but it seems to be a common complaint with the zwo supplied cables.
Jens avatar
Good point, and maybe a different phone as well. I haven't changed any hardware so far.
Philip F. avatar
My setup is slightly different in that I use either my Sony a7s or a zwo camera on the little skywatcher star adventurer gti. Both work fine. What kind of cable are you using?  An eqmod cable? Just a regular usb cable ?  I use the eqmod cable as it also works with my larger skywatcher mount too.
Randy Roy avatar
One thing to double check. When mounts slew to direct opposite parts of the sky, the problem is often the wrong longitude sign of +\- or E/W.  Likewise with N/S  latitude though this seems to occur less often. Check your acquisition app as well as your mount driver.
I doubt this is your issue, but sometimes the simple things cause the biggest problems.
Well Written Helpful Respectful Concise Supportive
Jens avatar
@Philip F.  I only use an usb cable, I will definetly try a different one soon, since I don't own a EQ mod cable.
do you see a big difference with the EQ mod cable?
Philip F. avatar
Jens:
When I was using my mounts with Nina, I often had issues until I switched to the eqmod cable.  When I got the ASIAIR, it was plug and play with the eqmod cable. I have never tried to use a different cable.
Plate Solving Issues With New Antila ALP-T 3nm Duoband Filter
Hi Folks, I haven't found much on the internet about this issue. I posted on CN this morning and I am waiting for a response. I am using an Explore Scientific ED102 Essential Series scope with a 0.8 FR/FF so the scope is operating at F5.6 at 571m...
Plate solving issues may explain telescope slewing misdirection problem.
Feb 28, 2025
Struggling to guide my Star Adventurer GTi with PHD2
Hello, I first got into astrophotography two years ago and quickly began accumulating gear slowly but surely as the months went by. I recently acquired a guide scope and a guide camera to improve my exposure times, which were previously limited to ~4...
Similar mount and guiding setup; troubleshooting guidance relevant to issue.
Apr 25, 2025
Guiding Struggles with ASI Air
Hi all, I recently bought an ASI Air Pro. Below is my gear for reference. I have been out imaging about 4 times with it and it has all gone quite smoothly except for the guiding. Before the ASI Air, I had so many nights where everything went amazingl...
ASI Air Mini guiding problems may share root causes with ASI Air Pro issues.
Mar 19, 2022
