freek fonteyne avatar
hello,
I currently use a Canon 70D with my 80mm refractor and have the chance to buy a used QHY8L cooled camera.
This is a 6 MP camera, while the Canon has 20.2 MP. Both sensors are quite big, which is good.
Question is: would the cooling benefit me to such a degree that the smaller amount of pixels of the QHY8L is cancelled out?
dkamen avatar
Larger pixels (which is what you get with the lower res since the two cameras have approximately equally sized sensors) means more signal per pixel. Cooling means lower noise. They are not two things that cancel each other, they both go to the same direction of increasing your SNR.
Resolution with the QHY will be about half, but realistically most of us with DSLRs resize at or close to 50% anyway. There is not a doubt the QHY would deliver better images with less fuss all other things being equal.
However, all other things are NOT equal: QHY is OSC CCD astrocam while Canon is OSC CMOS DSLR. It really is apples with oranges, many many dimensions to consider besides megapixels and SNR; extra cable and power source for cooling, reliance on a computer, different workflows, different sensor noise and response curves, different spacing requirements in your optical train….
Hard to tell wether it's worth it.
First mono camera: ASI294 vs ASI183 + filters suggestions
Hello, I've been shooting DSLR for deep-sky objects for about 3 months and I'm starting to see that the costly upgrades also have limits, on top of making the editing quite complicated. So, I'm looking to get my first mono camera and was ...
Discusses mono camera selection and cooling benefits for astrophotography imaging.
Dec 26, 2021
How to upgrade from DSLR to dedicated camera
Hi everyone ! First, I am going to explain my situation so that you can better understand my question. I am living in a Bortle 9 city in France, and I only shoot in Bortle 4 areas. This means I never shoot home, where I could use an electricity outle...
Directly addresses upgrading from DSLR to dedicated cooled camera systems.
Feb 8, 2022
2 DSLR Comparison
I, like many other, use routinely DSLR for deep sky imagining and I'd wager that most use a mix of Canons and Nikons, with few Sonys thrown in the mix. Some will be modified and some won't. Here is a like for like (if such thing exists) compa...
Compares DSLR performance for deep sky imaging, relevant to sensor considerations.
Dec 17, 2021
