Looking For $5K Or Less Astrophotography Setup Ideas
18 replies774 views
John J. DeAlessio III avatar
Hello. I'm currently trying to figure out what kind of ideal astrophotography setup I should purchase that would be a total of $5,000 or less for all of the equipment (mount, telescope, camera, etc). I want to get a setup that will let me mainly do deep sky photography, and some planetary cometary imaging as well. Here's one potential setup listed below that I've thought about after doing some searching online.
Mount: ZWO AM3 Mount & Tripod ($1798)
Main Scope: William Optics RedCat 51 ($865)
Main Camera: ZWO ASI533MC Pro ($799)
Guide Scope: William Optics UniGuide Scope ($114)
Guide Camera: ZWO ASI 220MM-MINI ($299)
Accessories: ZWO ASIAIR Plus ($299), ZWO EAF Electronic Focuser ($199), ProAstroGear Black-Cat Mount ($80), William Optics Cat Saddle Bar ($53)
Total: Around $4.5K
If anyone has any ideas or suggestions for potential setups that would fit in my budget range, please post them here.
Anderl avatar
Hey John,
- esprit 80 (1.4k)
- a touptek 2600c (rebranded) (1.4k)
- zwo am3 (1.7k)
- mini guide scope and some cheap 290c style camera (0.3k)
- mele quiter 3 (0.2k)
- zwo eaf (0.2k)
- dew bands (50 usd)
- small stuff like cables, usb hub etc (0.2k)
- pixinsight! (0.3k? Not sure)
Bit more than your targeted 5k but in my opinion a better setup. Bigger sensor, better bigger scope, no need for only zwo gear.
maybe you find a few of the things for less. Some of the 2600c clones can bought used for around 1k these days. Esprit 80 also comes up quite regularly.
pls don’t underestimate the amount of money you will spend on cables, adapters etc.
and pls do yourself a favor and just get pixinsight. I tried to go a cheaper route first and lost money and time on that.
cs
Andi
John:
Hello. I'm currently trying to figure out what kind of ideal astrophotography setup I should purchase that would be a total of $5,000 or less for all of the equipment (mount, telescope, camera, etc). I want to get a setup that will let me mainly do deep sky photography, with some planetary and cometary imaging as well. Here's one potential setup listed below that I've thought about after doing some searching online.
Total: Around $4.5K
I'd mod the above as:
Scope: Askar 103 APO ($999)
Flattener/Reducer 0.8x ($199) - Optional with a IMX533
Guide Scope: Any Chinese El-Cheapo 32mm guider (around 30/40 USD on eBay)
Guider: ASI120MM ($149)
Accessories: None (what do you need a electronic focuser for? That's what the hands are for) other than a filter drawer (ZWO): $79
Total: Less than target
P.S.: Get PI
Mount control: Any laptop.
Quinn Groessl avatar
The only planetary you're going to be doing with a Redcat 51 is lunar. I'm assuming your numbers are right. I'd change the main scope to an Askar 103APO Triplet ($1000) with the 1x flattener ($200). Then add the ZWO counterweight bar ($40) and something like a 4-6lb counterweight that fits ($40ish).
I'm not big in to planetary, but even what I suggest is probably not enough focal length, but if you want one scope for DSO too, compromises have to be made.
Joe Linington avatar
Not sure if it will fit the budget, but I would make compromises to make it fit.
Mount-AM5. Just spend the little extra now and not have to think about it later. No need for a weight bar or weight with any scope we've recommended. Nobody has ever regretted buying a bigger mount.
Scope-103APO as recommended or Sharpstar 61EDPH III if you want to save some budget. $749 with a 0.75 reducer/flattener. No need for a kit to fit a focuser, still a triplet, no need for a cat bar. You will never regret a decent wide scope. It will feel limiting at first but you will find yourself using it for many years to come even after you have bought 2 or 3 more scopes. As a bonus, for $199 more the SS 61EDPH has a 1x flattener letting you image at 270mm or 360mm.
If there is room left, buy an off brand IMX-571 and a mini PC or use an old laptop.
Save money with an SVBony SV-165 30mm guide scope, SVBony SV-905 guide camera or an ASI-120.
The ASIAir and ASI533 is not my favorite combo, I think NINA plus an IMX571 is a much better deal but it is OK for the budget and easy. So your call.
Don't forget a filter. You will want a duo-narrow band. Lots of people have had great results with the ZWO and SVBony 7nm Ha/Oiii filters and they are a good price. I love my IDAS NBZ but it isn't ideal under super polluted skies, I'm B5/6 and it is great.
Jan Erik Vallestad avatar
John:
Total: Around $4.5K
You can definetly save on the guide scope and guide camera with such a setup, the ASI120 and any kind of guidescope (even a finder scope) would do just fine and knock a few bob of your expense. If you do intend to go with the MC you would probably also need a filter holder and filters (depending on light pollution), but at least a UV/IR cut.
With the savings and left over room in the budget I would also perhaps suggest getting the AM5 over the AM3, just in case you want to get bigger scopes later on as the price difference isn't really that much after all. If you do get bigger scopes at some point you would also benefit from getting a 4.5kg weight (ioptron) and the counter weight shaft as well. For the RedCat you won't be needing it.
I'd say it's a pretty solid setup that will be easy to get started with. Lots of people prefer using laptops and various software - but it really doesn't get any easier than the AA+. Yes, you can get cheaper cameras from other brands that might be as good - but in my opinion the catch is it isn't as easy going as popping the AA+ on there and leaving it to automate your sessions. You will be stuck in the ZWO enironment though.
Deep sky and comets are fine with this setup, planetary not so much. For that you would need a completely different setup and preferraply a faster FPS camera - unfortunately the AA doesn't really let you use the full FPS potential of any camera, which would require a laptop and free software to record. Same goes for galaxies, you will do fine on the larger ones - but most are too small to image with this kind of focal length. Use this page as a reference for FOV for different scopes and camera pair ups: https://astronomy.tools/calculators/field_of_view/
Also, as others have mentioned: Pixinsight and RC Tools. Do not skimp on software.
Nick Grundy avatar
regardless of what you decide to get, I would certainly be stalking the classifieds on astromart and cloudynights daily. You'll likely be able to shave 30-40% off the equipment prices by watching for a deal as they come up.
for instance, I see an ASI533MC listed for $635 right now. And you get to skip sales tax. Just make sure you buy from someone with a good rating
Keller F. avatar
John J. DeAlessio III:
Total: Around $4.5K
UV/IR Cut Astronomik L2
ZWO 120 MM mini
Quinn Groessl:
Hello, and thanks for your reply. I already have a Celestron NexStar 4SE which I could use for doing solar/lunar and some planetary astrophotography. I also have a Canon EOS Rebel T3i camera which I've already used to image the sun (although not while connected to the 4SE yet, since I'm currently waiting for the necessary adapters to arrive).
And after looking at the Astronomy Tools link posted by another user, I see that I could get some great shots of the sun and moon that fill up most of the image.
Marc Monarcha avatar
Hey!
If you plan on just imaging with that scope (redcat 51), I would save some money and get a cheaper mount but upgrade the camera to a monocrome camera with some good filters. Here is what I would do:
Star Adventurer GTi: 670$
Redcat 51: 865$
ZWO EFW: 299$
Antlia 3nm S,H,O: 1185$
ZWO R,G,B: 169$
Guide Camera: ASI120MM-S 179$
Guide Scope: WO UniGuide scope 114$
William optics Cat Saddle Bar: 53$
Pixinsight: 300$
SSD (Samsung T7 shield or other): 80$
Jackery 240: 239$
Total: 4153$
Mind you you would be very limited to that rig if you get the GTi mount, since it will be limited to lighter loads.
Marc Monarcha:
Hey!
Redcat 51: 865$
ZWO EFW: 299$
ZWO R,G,B: 169$
Pixinsight: 300$
Jackery 240: 239$
Total: 4153$
You forgot the monochrome camera and you might be the first person I've seen to recommend going down 2 mount classes.
You could just squeak in a mono rig for $5000 with the AM3 but you are going to have to get a doublet scope, ZWO 7nm filters and buy the camera used (and maybe a few other things). Both of my mono rigs were under $4000 USD so it is possible.
True! hahah I was surprised myself to see how cheap this turned out. But, like you said, it could be possible. I just found that upgrading from my 533MC to my 2600MM was very much worth it this is why I suggested that. But adding the 2600MM to the suggested setup will crank up the price to over your budget...Maybe a 1600MM could work, with the star adventurer 2i. It would amount to just over 5000$. That being said, again, if you plan to upgrade to another heavier load, your mount will be of no good. If you plan on sticking to that rig, I would go for the mono rig.
Marc Monarcha:
Hey!
Redcat 51: 865$
ZWO EFW: 299$
ZWO R,G,B: 169$
Pixinsight: 300$
Jackery 240: 239$
Total: 4153$
Marc Monarcha:
Hey!
Redcat 51: 865$
ZWO EFW: 299$
ZWO R,G,B: 169$
Pixinsight: 300$
Jackery 240: 239$
Total: 4153$
Hello, and thanks for the suggestions. I already have a Celestron PowerTank 12V, so would that be sufficient for powering a Star Adventurer GTi mount?
Deepan Vishal avatar
I'd advice to invest least in the item that you are most likely to upgrade immediately.
E.g. If you think you'll upgrade your telescope, plan to invest in beefier mount and get cheapest telescope possible.
My suggested items -
AM5 2298
ASI294MM/ASI533MM 1280
ZWO LRGB (36mm) 200
EFW (36mm) 300
EAF 200
ASI Air Plus 300
ASI 120MM + Guidescope 250
I selected AM5 for slightly higher payload assuming you might get a bigger telescope.
You could swap 294MM with 533MM. Depends on your taste and preference for square or clean sensor.
I selected 36mm filters allowing room for future camera upgrade. You could save a bit here by going 31mm filters.
Also, you don't need Narrowband filters to get started. Ha might be the best place to start.
Depending on how much you could stretch, you could go for Askar 135/180, Astrotech AT60 with reducer or Redcat51.
If you would consider buying used you could save some money.
If it was me, other than the mount and Telescope, I would definitely buy all the accessories used.
Hope it helps,
Thanks,
Deepan
Eddie Bagwell avatar
Hi John,
Your list looks good, but I would consider upgrading the main telescope to the Askar FRA400 72mm f/5.6 Quintuplet FF Astrograph ($1199) and the matching guide plate ($31). That would still keep you under budget as you would not need the WO Black-Cat mount and WO Cat Saddle bar. You would also have some funds for a 1.25" Dual-band filter that you could attach directly to the ASI553MC with their supplied adapter. That would allow you to go after Nebulas in narrowband with your OSC.
Best of Luck and welcome to the AP community.
Eddie
Helpful Respectful Supportive
Marc Monarcha:
Hey!
Redcat 51: 865$
ZWO EFW: 299$
ZWO R,G,B: 169$
Pixinsight: 300$
Jackery 240: 239$
Total: 4153$
If I had to guess, it should be good enough for supplying the needed power to get the rig running. However, at 84Wh, I do not think it will last the whole night, especially with a cooled camera, unless your power the camera separately. I think you should start a new topic to get a good answer for that tough.
RadMan24 avatar
Gear list also depends on your observing site(s) and whether you plan on traveling or not.
Great traveler light setup to dark sky sites:
Mount: Fornax Lighttrack ii, with wedge and polar scope ($1,100; perioidic error 7arc/s in reality, though fornax claim is 1 arc/sec periodic error, in each case however, far better than many motorized mounts and doesn't require guiding setup or complexity in field).
Sirui Carbon Fiber tripod ($250), with a gimbal head or Fornax counterbalance set ($300-500)
Camera: Canon 90d (or similar dslr with shutter to keep dust off sensor; $900 new)
At this point, you have around $2,200 left over for telescope, or DSLR lenses. Lens: Many: Canon 200mm f/2.8 ii ($500 used, aperature 71mm, 1.7lbs); Canon 300mm f/2.8 ($3000 used ii, $2000 for i version, aperature 107mm, 5lbs ); Canon 300mm f/4 ($700 used, aperature 75mm, 2.5lbs). Each can take a teleconverter giving you multiple focal lengths to choose from. Nikon is another option. Sigma lenses like the 105mm f/1.4 are heavy but still work with this setup, and do widefield DSOs and meteor showers quite well; Sigma 40-35mm add in milkyway composite options.
Note with this setup, manual target acquisition favors nothing over 400mm in focal length unless its a bright object and you can star hop well.
This setup doesn't require any guiding, flats or bias frames, or darks and works best with simple processing: Camera raw files in a rawconverter (rawtherapee for example) which includes flat field correction, distortion correction, bias and other light frame adjustments) then use DSS to stack and use a color preserving stretch (siril for example) and then simple adjustments to final image.
Arpad R avatar
Hi John,
Have you thought about getting a Celestron C6 with a Hyperstar?
C6 (840)
Hyperstar for C6 (500)
Dew shield (60)
Guide scope and guide cam (300)
Asiair plus (300)
Eaf (200)
heq5 (1500)
OR
AM 3 (1800)
Asi 533mc pro (800)
Duoband filter (200)
If if you decide to get a mini pc instead of the asiair, you could go with the touptek 2600c.
tech_noir avatar
Hi John,
This pretty much mirrors my setup which I ended up with after an expensive journey of buying and selling things.
One difference is I have a 533MM and use the AM5 , as the AM3 was not available yet. 13kg is more than I will ever need with a mobile setup.
Some suggestions:
  • I can recommend the SVbony 32mm guide scope. I prefer it to my WO UniGuide. Results seem way better to me (no annoying tilt).
  • A 120MM would do this job perfectly well imho (even a 120MC will work). The 220MM is overkill here.
  • The ASIAIR mini works great for me. I would use the Mini instead of the Plus. USB 2.0 is near instant with the 533 (tiny file size). The Mini also works for casual planetary. It works well with the 2600 too.
  • I use the Black-Cat Mount and prefer the simple ZWO finder shoe. The Cat saddle bar is too tall and far out for my taste.
Some random idea:
The 533 goes very nice with a small reflector, perhaps a 130PDS or 150PDS, which could be bought second hand from the savings above. With the small 533 the coma corrector would not be necessary at first.
Any of these is a nice scope to complement the RedCat51 imho. Contrary to many statements - I found the newtons to work out of the box with no more than a primary mirror ring to get nicer spikes (otherwise they are really ugly) and a shower cap for the light leaks at the back.
clear skies
Power Supply / Battery Advice for My Astrophotography Setup
Hi everyone, I’m currently building up my astrophotography setup and I’d love some advice on power supply options. Here’s what I’m working with:Mount: ZWO AM3 Main Scope: Red-Cat 71 WIFDGuide Scope: UNIGUIDE 32MMGuide Camera: ZWO ASI 120MINIImaging C...
Power supply critical for mount and camera operation during imaging sessions.
Sep 2, 2025
Building My First Galaxy-Hunting Rig – Need Advice!
Dear Astro Experts, I'm new to astrophotography and could use some guidance. A fellow member recommended that I post my questions here. I'm considering purchasing the Askar 120APO telescope paired with the ZWO AM5 mount. My goal is to build a...
Similar beginner setup question with equipment selection guidance relevant to your needs.
Jul 21, 2025
