Baader UFC + S52/T2 for Nikon Z6
8 replies109 views
Miska Saarikko avatar
Does anybody of you use this combination of the Baader UFC (Universal Filter Changer) and a Baader Wide-T-Ring D52i to T-2 and S52 ?
Trying to find out what exact parts I would need to make this combination to work with my Nikon Z6.
And if I need any additional parts due to having a WO Redcat?
Please help!
Rich Sky avatar
Can you provide your camera and scope backfocus.
also, what is the tickness of the t-ring.
i use the ufc for my rasa, i may be able to help you, but i need the specs.
r
Rich Sky:
Can you provide your camera and scope backfocus.also, what is the tickness of the t-ring.
r
A Nikon Z6 has a flange of 16mm, and WO Redcat has its backfocus on 59.7mm.
The thickness would be 8.3mm on the Wide-T2 ring (S52).
An addition would be a 15mm extender tube to move the camera farther away from the telescope, according to PrimaluceLab.
Rich Sky avatar
59.7 mm scope backfocus
The BaaderUFC is 13 mm thick.
T2 ring is 8.3 mm
Baader + tring = 21.3 mm
59.7 mm - 21.3 = 38.4 mm
Not sure what your camera backfocus is? 16 mm
38.4. -  16 mm = 22.4 mm
if i understand your configuration correctly, it looks like you may need an additional 22.4 mm extender/adapter. Now, Miska, do your own calculation, as i do not want to take ownership of your issue.  At a minimum, you can ask Baader Planetarium/ or your adapter provider and they will kindly help you and provide the required adapters and distances + backfocus.
have a look at my calculation using the Baader UFC for my RASA. The link is.
https://www.astrobin.com/cwjsq6/C/?image_list_page=2&nc=&nce=
Baader and backfocus calculation
I guess my astro store is adding another 5mm extender along with the 15mm in the package deal for me. So there will be a 20mm addition to that calculation of yours and the leftovers should be manageable with the focuser on the telescope!?
Rich Sky avatar
How will you attach the ufc to the telescope?
you need an adapter on the camera side and you may need another on the scope side.
for example, if your scope is M42 male, you will have to order a M42 female baader adapter that will screw on the ufc filter drawer.
Have a look at this page at Baader Planetarium:
Baader adapters
I got this reply from PrimaluceLabs:
​Baader UFC telescope adapter with M48 female thread (1mm backfocus): https://www.primalucelab.com/astronomy/filter-wheels/baader-ufc-telescope-adapter.html
​Baader UFC (Universal Filter Changer) with S70 dovetail (13mm backfocus): https://www.primalucelab.com/astronomy/filter-wheels/baader-ufc-universal-filter-changer-with-s70-dovetail.html
​Baader UFC extension 15mm with S70 connection (15mm backfocus): https://www.primalucelab.com/astronomy/filter-wheels/baader-ufc-extension.html
​Baader UFC camera adapter S52 for Wide-T rings (2mm backfocus): https://www.primalucelab.com/astronomy/filter-wheels/baader-ufc-camera-adapter.html
​Baader Wide-T ring for Nikon Z with S52/T2 (8,3 mm backfocus): https://www.primalucelab.com/astronomy/t2-rings/baader-wide-t-ring-for-nikon-z-with-s52-t2.html
​By adding these backfocus to the 16mm of the Nikon Z camera, you will have the 55mm backfocus that is the same of a DSLR camera, but with the possibility to insert the Baader filter holder and a filter in front of the sensor.
Rich Sky avatar
Yes, i see the camera side and the scope side Baader adapter. Good to go.
are you going to get narrowband filters?
ok Miska, good luck with your setup, looking forward to seeing an image with your setup.
Clear skies,
R
Nah, thinking of getting a Baader UHC-S filter to start with.
Kinda live in a country with 89% light pollution and the only places that don't have LP are the mountains and few National Parks up north.
Thanks bud!
Clear skies
