Menelaos avatar
Hello guys.
I just acquired a Sky-Watcher 150/750 PDS Newtonian and I am new to the whole Newtonian thing, I watched videos and read articles about how to collimate and I follow through all the techniques (Cheshire eyepiece, collimation cap, laser collimator), and then when I go out imaging I even do a star test and it looks perfect. However, as soon as I take an image in focus immediately in the corners only on one side I can see distorted stars. I use a DSLR Canon 250D modified with a MPCC iii Baader coma corrector. Obviously I am doing something wrong. Any Idea what is going on here? Can anyone suggest a good book for more advanced collimation that could possibly help?
Thank you guys.
Here is how it looks like.
Quinn Groessl avatar
Sounds like tilt and/or focuser sag.
You haven't go a problem with collimation but with tilt and the MPCIII isn't especially tollerant of tilt in my experience. This said, that CC isn't the best around anyhow. The source of the tilt can be anywhere within the image train; focuser sag, tilting within the compression ring with the CC, the CC to camera intrface and so on. Given that is pretty much uni-directional  shimming might do the trick but isn't going to be an easy job.
Menelaos avatar
shouldn't tilt be eliminated when collimating on a star? I mean isn't this the point?
Gerassimos Arsenis avatar
Looks like tilt of some sort. Try rotating the camera and take several exposures to see how it changes. I have the same issue and also use Newtonian along with MPCC. Like others mentioned, the tilt can come from anywhere so it takes a lot of experimenting…
They would need to know how to collimate in focus with all the imaging train in place, which isn't easy for anyone and requires dedicated software and hardware to do it right. And is no gurantee that once you put on your DSLR things won't change. Not for the faint of hearts! Never mind that if the focuser is sagging then the is no redress possible unless this is corrected first.
But let's assume that the scope is collimated (or collimated enough for imaging purposes) then you would see soemwhere within the image the locus of zero (or near zero) coma, the optical axis. If there is tilt then the tilt components add to the deteroration of the image two-fold: one by adding the tilt's own aberration and secondly by shifting the optical axis away, in this case outside the sensor boundaries.
Peter Graf avatar
With the two screws that the camera is clamped to the focuser/2" adapter, I always experienced mild to strong tilt (APS-C DSLR or 533MC), and as the MPCC is quite short, ASTAP generally complained.
In the end, I have switched to a Baader Clicklock clamp and am very satisfied. According to ASTAP only 1-3% tilt which is fine for me.
The only disadvantage with the 150PDS and default focuser - I can no longer get into focus with the guide camera when using the ZWO OAG. That's why I'm guiding with the separate guidescope again. But with the 750mm focal length, no big deal i guess.
Cheap Newtonians and a coma corrector are actually pretty cool!
Ignore my processing, but I wanted to highlight to newcomers on here that you don't need to spend thousands on your first scope (OTA) to get nice sharp images. The equipment here is a Skywatcher 200 DPS 8" Newtonian together with the Skywatc...
Collimation relevant to Newtonian telescopes; author mentions star elongation issues.
Mar 28, 2022
Bad collimation or defect on Apertura 8" RC
HelloI recently purchased an 8" Aperture CarbonStart RC telescope. In order to check the collimation, I removed the secondary baffle extension, so I can see better the entire reflection of the primary in the Cheshire eyepiece. One thing that cal...
Same telescope model; collimation and optical issues directly relevant to your setup.
Jan 23, 2025
Problem with skywatcher 150/750 and cyck focuser. I can´t get focus
Hello. I would like to know if anyone who has changed the focuser on this Newton has had focusing problems. In my case, when changing from an SV200 filter to an Lpro filter, I cannot focus for 150 focuser steps. The focusing shaft is fully inserted a...
Same telescope model; focusing problems may relate to your corner distortion issue.
Feb 17, 2025
Coma problems on images
Hi, After few nights trying to adjust the correct distance for the coma corrector (the Baader MPCC MKIII) i always see some stars on the border that are not circle. Could be my collimation that is not perfect? This is a 3min test no dark/noflat etc. ...
Addresses collimation problems relevant to Newtonian telescope troubleshooting.
Oct 18, 2021
My move from refractors to newtonians
For many years I have been using refractors for imaging (I could afford it, before retirement !). I finally had to admit that to achieve good results, only high end refractors will do the job, i. e. those using top quality glasses - triplets or more....
Newtonian imaging transition; may address optical performance challenges you're experiencing.
Apr 27, 2025
