Mossyback avatar
I’ve decided to switch to Stellarium for the image source with N.I.N.A. I tried it out today and got the message that I had to approve it in Stellarium. How do I do that?
Hank
Nick Grundy avatar
I assume you've already selected Stellarium as the planetarium in Nina?
If that is done and the local windows firewall isn't blocking anything, then you need the "Remote Control" plugin setup in Stellarium
I'm guessing you have "access requires authentication" checked? As long as you don't keep your imaging PC on the internet, then you can just disable that.
Mossyback avatar
Thanks, Nick. This is the information I was looking for.
Hank
Nick Grundy avatar
no worries Hank, someone told me how to do it when I first got stuck. Sort of how all this stuff goes
1 point for Astrobin
Brian Puhl avatar
Just a word of advice, if you're running stellarium on a remote PC, try to set a manual IP address in DHCP settings of your router.    Sometimes the router will change the IP on you and you'll lose your connection to stellarium.       I love this tool, very handy for framing my target.   Both telescopes sit outside and both can communicate with stellarium on my desktop to acquire target position and framing
Linwood Ferguson avatar
You can use Stellarium as a source for framing and coordinates, to import into the targets/framing wizard in NINA, and uses the Remote Control plugin and port setup in NINA.
You can also use Stellarium to show the current pointing location of the telescope (or even to point the telescope directly) using the Telescope Control plugin with the mount's ASCOM driver.   NINA does not participate in this (though it shares access to the mount).
These are separate setups, some use one, some use the other, some use both.  If using the latter with a driver that counts connections, like Astro Physics, bear in mind it creates an additional ASCOM connection to the driver if running (i.e. you might need to close stellarium to close the driver window).
Mossyback avatar
Thanks, Folks for the additional information. I’m not sure that I’m using it correctly but I appear to be getting the coordinates into the advanced sequencer. I search in Stellarium for the object that I wish to photograph then switch to N.I.N.A. Clicking the little teardrop brings up the coordinates.
Is It Me or the Camera?
After a fantastic first night out with my new ZWO ASI533mm, things took a turn for the worse tonight. (MtY Mount, 120mm Esprit, N.I.N.A. and the above camera on Windows 11) I was able to do an autofocus run on NGC 5457 using Hocus Focus with no probl...
Uses N.I.N.A. with similar setup; may have encountered Stellarium integration issues.
May 27, 2025
My Problem with PhD2
I've never been able to get PhD2 to work as it should. I know that it's me, not the program. For background, my setup is an MtY, TSX, N.I.N.A. and an Esprit 120mm. I've had reasonable success simply using the above equipment for up to thr...
Discusses N.I.N.A. software troubleshooting; relevant to software configuration problems.
Jun 19, 2025
