Michael Taube avatar
Hello!
I you are interested in a dual rig, when two or more telescopes are placed on a single mount for imaging, please share your thoughts with us.
smile
David Redwine avatar
Michael, thanks for starting this group.
Here's my multi scope set-up.
https://www.astrobin.com/yd5gn8/?nc=user
My latest 2-fer:
Main Scope on M110:
https://www.astrobin.com/s9su31/?nc=user
Wide-field captures Andromeda:
https://www.astrobin.com/1jbswc/?nc=user
Dithering for the simultaneous capture  was managed by two instances of APT running,  The exposures and delays were equal.  Multi-camera sync was run in tight mode with the long FL scope (the 8" Edge) being the dithering server. PhD2 was controlling the actual dithering in server mode.
Robert Eder avatar
this is my dual rig with two little baby newtonians:
I also use APT with PHD2 to synchronize and dither the two cameras. It works like a charm.
Usually I have OSC(DSLR) on one scope and dual band on the other one. And especially in the short summer nights I can double the exposure time.😃
CS, Robert
Filter comparison for fast filters, Antlia ALP-THS vs. Baader Highspeed 3.5/4nm filters
As I had quite good results with the normal Antlia ALP-T Dualband Filter I also bought the High Speed Version of that filter as soon as I realized it exists. So now I have a set of Baader High Speed Filters and the Antlia, so why not try to compare t...
Filter selection relevant to dual rig imaging setup and equipment choices.
Jul 4, 2022
Wiring up and Cable Managing Your Telescope Platform
Hi Folks, When you have a lot of components mounted on your telescope platform you can end up with a real rat's nest of 12v power and USB cables. Realistically - this kind of thing is always a work in progress as you add to or modify your telesco...
Cable management essential for organizing multiple telescopes on single mount.
Feb 7, 2022
Dual-Narrowband filter+OSC vs. Ha/O3 filters+Mono Comparison
Hello everyone, Lately I have been thinking on which of the following - Dual-Narrowband filter+OSC and Ha/O3+Mono - is most time efficient for shooting and I'm starting to reach the conclusion that Dual-Narrowband filter+OSC may be a better optio...
Dual-narrowband filter discussion applicable to multi-telescope imaging configurations.
Jan 11, 2022
