POWER SUPPLY: Diagrams Thread
3 replies145 views
Santi Astro avatar
Hello colleagues!
The use of a power supply is often a headache for amateur astrophotographers (my case) and I haven't found a topic where this is discussed.
I think it's a good idea to make a compilation of the schemes you use to power your equipment when you go to do astrophotography in the field and there is no access to a socket like at home, I think it can be very useful for many users and possibly for yourselves if you find an easier/lighter/cheaper way to power your equipment.
I think it would be useful to indicate the equipment to be powered so that everyone can check if this is the case for them. Also, I think that the most interesting thing about this topic is the way to connect things, and not so much the capacities and other technical data of the batteries, but all data is welcome.
Also, the motivation for this thread is that I am not entirely clear on how to connect a 12V battery to a laptop that requires 19.5V, I know what capacity to buy the battery but I don't know how to connect it. If you can help me with this I would really appreciate it.
Clear skies from Spain!
Santiago
Respectful Engaging
Inverter, that's the answer. Just get one that has enough capacity (amperage) to power all you equipment. As for batteries, the best are the deep discharge marine lead-gel sealed one, if you ask me. Again, make sure you have enough juice to power all your equipment for the duration.
Santi Astro avatar
Thanks Andrea,
I knew that an inverter could be used but it costs about €100 and I have seen that they are a bit bulky and I was thinking that there might possibly be some other way.  If there is no other I will go for it.
Thanks Andrea,
I can source them from eBay at around 30 euros:
6000W Car Power Inverter Converter DC 12V to AC 240V 4 USB 2 UK Socket Sine Wave | eBay
Power supply for astro imaging
Hi all, I'm looking for suggestions regarding a good quality power supply for my astro imaging equipment. I've realised that if I had a power supply failure due to high voltage output (which I have happened in the past with different equipmen...
Directly addresses power supply selection for astro imaging equipment needs.
Mar 15, 2025
Power Station for occasional use
Hello all, I know this topic comes up a lot, but i’m trying to consolidate my research with a few opinions of those who might be in the same boat as me. My normal set up at the moment is a SA GTi mount, with a REDCAT 51, ASI533MC Pro, filter wheel, E...
Discusses power station options for field astrophotography use cases.
Aug 31, 2025
RC product design deficiency in Technical Forum
Hi, just wanted to inform you about this topic here: Thread on AstroBin I believe this is interesting for all of us. CS Michael
Power supply guidance for astrophotographers; practical technical resource for community.
Jan 27, 2022
