DSLR question
1 reply•123 views
danbi avatar
I connect my Canon 70D DSLR to my ASIAir Mini Mini with a USB cable. And it works fine. But I notice theres a small plug in hole on the mini labelled DSLR, and I wonder what thats for.
Thx for reading.
Scott Horton avatar
Its an optional shutter release cable port - should not necessary if you have control with the USB cable.
Wired Ethernet problems
Hello, All A little backstory. The only way I can control the ASIAIR Plus (AAP) with my Lenovo tablet is to set my tablet wifi network to the AAP access point network. After AAP bootup I then can go into Station Mode using my home wifi network - afte...
ASIAir Mini connection options; Ethernet alternative to USB cable.
Apr 20, 2025
iOptron Skyhunter and ASIAir support
I've an iOptron Skyhunter with iPolar, I am planning to get ZWO ASIAir Mini computer to control my set up but unable to get any resource saying if it is compatible with the mount or not. I've checked ZWO support website and this mount is not ...
ASIAir Mini compatibility and connection setup with telescope equipment.
Jun 11, 2025
Asiair + hub usb
I own a Asiair Pro and a Asiair Mini. Normally I connect filter wheel and guide camera to the hub of a Asi 183MMpro, then the camera to the Asiair; I connect EAF and my mount to Asiair and the last usb port normally is used with a flash usb. As I am ...
ASIAir Mini USB hub connectivity and device connection methods.
Feb 12, 2025
