Starting astrophotography with TMB "LOMO" 80/480
2 replies200 views
Skygazer avatar
For many years, I've owned a TMB "LOMO" 80/480 apo telescope along with a G11 Gemini 1 mount. I've been trying to figure out how to start using my TMB telescope and what accessories I need to buy, as well as finding the best combinations. I also have a Canon 6D (non-modified) and I'm interested in learning how to capture images with this setup. However, I'm considering purchasing a dedicated astrophotography camera. I'm not sure which one to choose, so I hope someone can provide some guidance. As I'm just starting to learn, could you recommend any good books or resources to help me learn astrophotography?
Thank you very much for your assistance!
Regards, Benjamin
Lynn K avatar
Books I would recommend.  "The Astrophotography Manual" by Chris Woodhouse. Published 2017, and new software & equipment has come out since then, but basic acquisition and processing hasn't changed.
Another is "The Deep-Sky Imaging Primer" Also published 2017. This book jumps into technical jargon quickly, but till good to have.
I've been imaging over 18 years, and learned from out dated books by now.  I bough the two above  books a couple of yeas ago, and fine reading them, even at this point in time, beneficial at feeling in technical details that I never fully understood in depth.
One issue you may incounter with your 80mm scope is focus travel. These scopes were often designed to use with a 2" diagonal or even a bino-viewer.  You may need a extention tube to come to focus with your DSLR.
Lynn  K.
Skygazer avatar
Hi Lynn!Thank you very much! I will search for the books you recommended.It's true that I can't achieve focus with my Canon 6D. I will ask a vendor what extension tube I need.I have searched here on AstroBin, but it's hard to find any users who use this scope.My goal is to learn as much as I can and later buy a Takahashi FS60 CB and eventually a TSA-120, two scopes that I find very appealing. Many years ago, I had a Takahashi FS78 (for visual use only), and it was an amazing scope.
//Benjamin
3" Focuser Support for Orion 8" Reflector
Hi folks, So I've been recently looking to finally upgrade my camera train. I've been looking at the 6200mm / Zeus-M cameras, but learned that going to such a size would require a 3" focuser to ensure I don't have vignetting issues&#...
Discusses camera train upgrades and dedicated astrophotography cameras relevant to your needs.
Jun 3, 2025
Building My First Galaxy-Hunting Rig – Need Advice!
Dear Astro Experts, I'm new to astrophotography and could use some guidance. A fellow member recommended that I post my questions here. I'm considering purchasing the Askar 120APO telescope paired with the ZWO AM5 mount. My goal is to build a...
Beginner seeking guidance on building astrophotography rig; similar situation to yours.
Jul 21, 2025
My Learning Journey: Choosing an Astrophotography Camera (Beginner-Friendly Blog Post)
Hi everyone, I’ve recently started putting together a small website to showcase some of my astrophotography images and write about what I’ve been learning along the way. While I don’t have many blog posts up yet, I just published one that’s close to ...
Directly addresses choosing astrophotography camera for beginners; highly relevant to your decision.
Jul 5, 2025
How to use ZWO ASI 385MC
Hello! I am new to astrophotography and I need a little help getting started. For some reason, when I attach my ZWO ASI 385 to my telescope (I have an Askar 103 APO), I can't see the sky. If I get an object centered in my telescope, (such as the ...
Getting started with dedicated astrophotography camera; addresses setup and configuration questions.
Feb 2, 2025
Noobie requires help
Okay, I'm faced with a very serious choice. I'm becoming more and more attracted to DS astrophotography, and I'm currently choosing (my first) telescope. To avoid frustration and save money in the long run, I decided to immediately buy eq...
Choosing between camera options for deep-sky astrophotography; matches your consideration phase.
Mar 2, 2025
