Thoughts on a slightly different acquisition process
Astrobin Community Survey 2 replies111 views
Michael Ring avatar
I am trying to catch up on the time I have lost because my Samyang is at my parent‘s home….
But part of my thoughts is also about beeing as efficient as possible, so here are a few of my ideas, comments welcome:
- shooting at f2 to get maximum efficiency for building up SNR
  The reason I did not do shoot at f2 before was quality of stars, but more on that later
- for now, shoot only 2h per field
  2h is not enough for our goals at my Bortle 4 skies but the required 4h simply take to long for my taste, so the plan is to reshoot the rest in the next year and to cover more fields per year.
- Always shoot on the same side of the meridian in one night
  Meridian flips take their time, decreasing efficiency. When only shooting 2h it is quite easy to shoot targets high in the sky, and then to switch to another field that is again on the same side of the meridian. Besides beeing more efficient it also makes guiding more stable, in few cases I have lost subs directly after the flip because the mount first needed a while to re-adjust.
- Shoot good stars in an extra session
  Stars can be done at f2.8 or higher as they are bright anyway. Half an hour is also normally good enough for the stars. Still have to find the f-ratio for nicest stars
- Play with GAIN
  With narrowband I have completely switched from doing 10min subs at gain 100 to 5min subs at gain 200. Less frames to drop when something goes wrong… Should in theory also work well for new 1min subs at gain 200, dithering needs to get adjusted to run on every 2nd sub, otherwise the dithering process eats up to much imaging time. Perhaps also dithering every 3rd frame could be an option.
Any thoughts on this, especially @James Tickner , could this work with your process, one thing I might have to do is to throw away the f2 stars and replace them with the f2.8 stars for final submission
Michael
James Tickner avatar
@Michael Ring Thanks for the comments. Here are some thoughts (in no particular order!)
  • So far Brian and I have both been shooting at F/2 (Brian at 200 mm full-frame, me at 135 mm APS-C). Whilst star quality in the extreme corners isn't perfect, it's not that bad. Plus once we start to mosaic images, the extreme corner of one field ends up being reasonably inside the next field over. I haven't played with the weighting of adjacent fields too much yet during the mosaicing process (I just use a linear 'fade' for the last 10% of the field width), but this could be tweaked to favour the image with the better star HFR.
  • I suspect we'll find that image noise varies quite a bit from field to field, not only due to different locations and different equipment setups, but also from haziness, altitude, light domes etc etc. My philosophy is to keep grabbing fields of reasonable quality without worrying about perfection. We can always come back and grab some frames if we have to.
  • I also avoid meridian flips. Apart from the loss of imaging time, I've also (oddly) found that I'm getting field rotation of 7-8 degrees after the flip. My guess is that my homemade mount has the lens axis set at an angle to the DEC axis. I haven't worked through the maths on that one, but it's the only reason I can think of. Sticking to the east side of the meridian avoids the problem. My sky is also darker in that direction.
  • I'm currently shooting 1 min subs with my camera on minimum gain (100 on IMX571 sensor). This is mainly due to the rather poor tracking of my EQ5 mount and avoids too many dropped frames. A plus side of poor tracking is that I don't need to dither though - that just happens naturally .
  • I'm not sure about shooting stars separately. One of the aims of the project is to go fairly deep on both stars and diffuse objects. I worry that this approach would introduce another variable into the mix.  @Brian Boyle might have some thoughts on this one.
  • I'. working on getting the automated QC reporting software up and running - hopefully another week or so. This should generate a fair bit of information for each image, including alignment, field distortion, colour balance, sky brightness and noise levels and star quality. Hopefully this will take some of the guess work and speculation out of finding the best settings - nothing like throwing some data into the argument .
Looking forward to seeing some of your fields come though!
Helpful Insightful
Brian Boyle avatar
Hi @Michael Ring  - Great thoughts, and I agree pretty much with @James Tickner responses.
I shoot wide-open, try to take as close to the meridean as possible, without crossing.  If I do cross [briefly] I don't flip.  I shoot 25 x 3min subs with dithering every 3pix dither every  2 subs.  I don't  shoot separately for the stars.  We will end up with more saturated stars, but that is a small disadvantage compared to the increased complexity of processing and QC.  Indeed this is where the bottleneck is currently, and I am strongly with @James Tickner on this one - lets gather enough data to get a large enough sample with which to do the QC.  Only with a large sample we will be able to establish the relationships between the wide range of variables we have in this survey; geography, equipment, sky brightness, transparency, seeing.
I am really looking forwards to James' QC and mosaicing work, which will give us great insight to the data taken so far.
The only other observing protocols I follow are
1) Re-focus for every field [1.5hours]
2) Don't observe lower than 45deg above the horizon.  [Avoiding light domes - and for me going "below the Pole" on far Southern fields]
CS Brian
RCC - ways to improve acquisition and processing, 1 year into astrophotography
Monday, June 16th was exactly 1 year since my first astrophotography session with a 85mm lens on an astro-modified Nikon Z5 MILC and a SW SA GTi mount. Since then, I have tried various camera lenses and 3 smallish refractors. My current rig is a WO G...
Discusses efficiency improvements and optimization strategies for astrophotography acquisition.
Jun 18, 2025
[RCC] Rosette Nebula with Samyang 135mm and ZWO ASI664MC
Hi All, Happy to get some constructive feedback on my image especially I expect the processing. First a bit of background, I’m based a few miles from Manchester airport in the UK. I’m in a built up area so a limited view of the sky between neighbours...
Author uses Samyang lens; discusses shooting strategies and image quality considerations.
Jan 27, 2025
