I have had this camer for a couple of months and I have not been able to properly correct images. I am coming from a 294mm and mc and I am using 33 darks at matching temp and 33 flats at matching temp. flats are calibrated with flat darks. Images are processed andually and with WBPP with the same correction issue.
I have hit a brick wall with this issue and I would like to figure out what I am doing wrong. I have used the camera with a hyperstar and with a starizona sct iv reducer.
(top) uncalibrated single sub (bottom) calibrated stack with flats and darks in WBPP.
I can answer any other questions that you might have. I would like to get this issue figured out
Thank You for any help!
