Struggling to capture crisp Jupiter or Saturn images
ArnyAshraf AbuSaraandrea tasselli
27 replies728 views
Arny avatar
Despite all efforts my Jupiter & Saturn images stay blurry an flat - any advice out there?
equipment
- Celestron EdgeHD 11
- cooled Asi2600mc OSC via AsiAir, Sharpcap and AsiCap
- under a bortle 5 sky
acquisition
- between 1000 and 3000 frames
- manual and autofocus using EAF on AsiAir plus
- with no, UV/IR and OHC filters
processing
- autostackert top 5% frames only and drizzle 3x
- registax to sharpen
- alternatively directly through Sharpcap
I have tried all permutations of
- exposure 3-5ms with gains 400-200
- minimal resolutions of 320pixel up to 960 to drive fps
- resulting fps 15-50
- histogramm well below 200
- driving the camera on USB3.0 direct with Laptop and AsiAir plus
- trying with and without filters
No distinct results differences keep frustrating me, as stacked images look like this
and sharpened not much better.
What am I doing wrong?
Could bad seeing drive these poor results? Or is it focus?
Any advice welcome :-)
Alan Hancox avatar
Check your collimation. With planets SEEING is EVERYTHING!!!! You won`t get a good image if the conditions won`t allow it……
CS and keep at it!!
Alan
D. Jung avatar
Did you remove the protective film from the telescope? smile
Olaf Fritsche avatar
My planetary photos look similar. I suspect it is due to the air turbulence. Maybe it would be better to take photos in the second half of the night, when the temperature differences between ground and air are smaller.
Thomas W avatar
What f ratio are you working at? You said no UVIR cut filter - should be using one with an OSC camera (IR capture aside) to prevent muddying from the CFA overlap below 400nm and above 700nm.
How high was the planet when you took the images? Anything less than 30 degrees is very likely doomed to failure but you want to go at it when is as high as it can get. And seeing rules supreme with planetary imaging so if the seeing isn't good you're just wasting time. I mean really good, steady as rock good.
Oskari Nikkinen avatar
Are you using a barlow with this setup? Theoretical ideal sampling for planetary can be approximated to: Ideal f ratio = pixel size in microns x4. So in the case of your 3.76 micron it would be roughly f/15 so a 1.5x barlow needed. I am not math savvy myself so couldn't tell you exactly what reasoning was used to arrive to that conclusion, but some other math savvy people have so i trust that. But safe to say that you are probably a little bit undersampled if you are at f/10.
Other than that, you need frames, lots and lots of frames. Think in the tens of thousands rather than thousands. For best results you really ought to use a capture computer that is capable of supporting full USB3 speeds so that you can cram as much frames into a recording as possible.
Collimation needs to be better than perfect for ideal results as well. Very small issues lead to obvious loss of sharpness for planetary stuff. Another thing that cant be overlooked is focusing. You need to spend some time with focusing on the planet itself (not on the Moon, or on a star, or with autofocus but manually) to get the best results. You could spend half or more of your time racking the focuser in and out in search of that perfect micron small spot where the planet is at its sharpest. This is tricky if the seeing is not very good, because your focus will go in and out with seeing.
And one more thing, the elevation of the planet needs to be as high as possible for best results. Below 30 degrees we start to see serious issues and below 20 degrees will be very difficult. Ideally the planet should be as high as it can possibly be.
Ashraf AbuSara avatar
The first problem is drizzle 3x. Get rid of it. I had the exact same problem and it completely went away when I stopped using drizzle. Image became much sharper, even when I end up resampling x2 or x3. The second problem is you need to use a barlow for approriate sampling. Ideal f ratio would be F/18.5, so a 2x barlow bringing you up to f/20 would work well.
Norman Tajudin avatar
I would agree with Alan that seeing is everything.  I have an incredible Maksutov with high magnification (f/15) but I live at sea level here in Huntington Beach, California.  I have now accepted that I can't try to capture at that magnification given that I'm punching through a lot of turbulent air.  I can't wait to take it out to some dark sky locations in the future though…
Clear skies,
HBNorm
Well Written Insightful Respectful Concise Supportive
Arny avatar
about 25° - my current max at 52N latitude -
plus turbulences that the video would dance.
So you mean I was doomed anyway and did not make major mistakes?
Frustrating but somewhat comforting ... Thanks !
Arny
Arny avatar
Ashraf AbuSara:
I tried without drizzle, but no difference, the 320p solutions just were too small. But resampling is a good idea.
Barlow I did not dare for the worse f-ratio - I am already at 0.28"/pixel.
What would it help to go down to 0.14"/pixel?
Arny avatar
Oskari Nikkinen:
Thanks for your advice.
Even though I don't get, why f/10 is too little, I buy that many of you know from experience :-)
Focus is indeed painful and close to impossible with bad seeing. Good to know that manual beats auto- or starfocus - taking half an hour or more was necessary.
Arny avatar
D. Jung:
Indeed I thought of something like that :-)
Arny:
Not one bit. In fact it would have made it worse. Stick with Jupiter this season (and the next and the next too). Look at the thing with an EP at high magnification (>300x) and if it looks steady for more than a fraction of a second then have a go at it. I'd recommend no more than 14"/px in the best of seeing and less if seeing isn't great (but at least decent).
Ashraf AbuSara:
The optimal focal ratio for planetary imaging is dependent on two things, your camera's pixel size and your seeing conditions. Typically for good seeing you need to aim for 5x your pixel size. If you seeing was not really that good then 3x the pixel size, and for exceptional seeing you can go upto 7x your pixel size.
This FAQ is really helpful and helped me a lot.
https://www.cloudynights.com/topic/812022-planetary-imaging-faq-updated-january-2023/
Arny:
Not one bit. In fact it would have made it worse. Stick with Jupiter this season (and the next and the next too). Look at the thing with an EP at high magnification (>300x) and if it looks steady for more than a fraction of a second than have a go at it. I'd recommend no more than 14"/px in the best of seeing and less if seeing isn't great (but at least decent).
I do not agree with this advice. I think the point here is to help them image Saturn, not to dissuade them from imaging it (or worse, tell them to wait years). I took this image only 3 weeks ago with the 533mc pro which has the exact same pixel size, and a 2x Barlow using a C11 XLT at F20. This in fact was my first attempt.
I am by no means an expert, but if I can take this image I think the OP can do just as well if not better assuming their seeing conditions are not terrible.
Well Written Helpful Insightful Concise Engaging Supportive
You took that image from Southern Texas, right? What is the latitude of So.Texas, pray? I bet it isn't 52deg N. For us fellas from up North Saturn is no go zone for the next 2 years at a minimum.
A quick search of Astrobin for folks imaging from Germany just 13 days ago this season using a C8 and a 2x Barlow from Dusseldorf:
https://www.astrobin.com/ccze18/
One lucky shot won't change the general outlook: Saturn isn't worth a go for high Northern latitudes, especially so for someone like the OP which isn't experienced in planetary imaging. So they shouldn't feel bad if their attempt resulted in frustration. It is the expected outcome.
Supportive
I am not saying they should feel bad. I think those examples just demonstrate that there is perhaps some room for improvement. I will leave a link to the rest of the "super lucky shots" from Germany this season.
https://www.astrobin.com/search/?q=&d=i&subject=&telescope=&camera=&date_published_min=2023-06-11&date_published_max=2023-09-09&country=DE&subject_type=SATURN&sort=-published
@Arny
One other important point I forgot to mention is that collimation is critical according to the best ones that do this. That FAQ is extremely helpful.
Arny avatar
Ashraf AbuSara:
thanks for the inspiration, Ashraf :-)
Arny avatar
Ashraf AbuSara:
it is really good - thanks for linking to it, Ashraf!
Especially the intro, that almost all that counts in DSO does not in planets opens the mind to reset :-)
Arny
Thomas W avatar
I took this a couple days ago using a C8 from 52N. Saturn was at about 26 degrees in altitude. Decent seeing but very poor transparency. Not the best by any means but I am happy with it given the conditions.
It is entirely possible to get usable (very subjective term!) data through low altitudes, you just need to be patient for moments of good seeing as Saturn is not favourably placed. On that particular night seeing may just have been very poor for you. Needless to say there are a hundred other things to consider. For a start try and get a barlow to operate in the f18-20 region, increase exposure to the 10-40ms region, triple check collimation and do a star airy disk test, refocus fairly often, make sure the OTA has enough cooling time to equalise, make sure you are using a UVIR cut with that camera, use an ADC as improvements are significant at these altitudes, finally record lots and lots of data but only process the best.
Arny:
Ashraf AbuSara:
Arny
Glad to hear that! That subforum in general has excellent and very experienced planetary imagers who are very helpful too.
Great advice and amazing result.
