Hi All, I have a question for the community:
So far I have used my AzEq5 mount on a tripod that has a blocking shaft of 10mm diameter. The tripod seem a sturdy one, with 2" diameter legs. I would like to mount on the same tripod an AzEq6, that in principle needs a 12mm diameter blocking shaft. I can use adapters that bring the 10mm shaft to 12mm diameter to fit into the AzEq6.
Would you be concerned from such a solution?
Thanks in advance.
