How to process dark nebulas
5 replies505 views
DSalex_astrophoto avatar
Hey guys I need help. I'm doing a 10 hour project with my skywatcher 150/750mm and my dslr shooting at a dark nebula like the snake nebula. I basically don't know how to process this type of dark nebulas, I'm not sure if it requires some different techniques, idk please give me some advise on how to process it in photoshop
Morian avatar
Hey.
Here is a link for different type of process in photoshophttp://www.astronomersdoitinthedark.com/Bringing-Out-the-FaintStuff.php
Christian Vulpescu avatar
Good question. Is there any work flow for Pixinsight somewere? I don't know how to get that brownish golish tones in the black dust lanes.
Wim van Berlo avatar
For PixInsight, try this
http://pixinsight.com.ar/en/info/processing-examples/49/barnard150.html
Some of the process steps are outdated, and use scripts that may not work anymore, but the general flow should work.
Thank you so much.  :-)
maxchess avatar
You say you are  doing 10 hour project with my skywatcher 150/750mm and a dslr, but you don't mention the mount. Is your 10 hour total integration time of multiple exposures?  It seems a lot?
Assuming you are collecting enough long exposures, then you may want to try an alternative to photoshop. I would recommend Startools. It's easy to learn and inexpensive and has great tools for making the most of DSOs.
Max
How to improve your astro images ...
Anyone who has dabbled in astrophotography will know, the move from your dark linear image to a stretched image which shows all that wonderful detail you have spent hours capturing, is a critical step in producing a fine finished product. As a step t...
Discusses stretching linear astrophotography images to reveal detail in nebulae.
Dec 10, 2021
Feed -my Pacman- Back
Hi All, So, I ve just finished processing the Pacman nebula, roughly 17 hours worth of data processed in there (mono), and I think I ve hit a ceiling in either the location from where I'm taking pictures from at the FL I'm shooting with, or m...
Author processed extensive nebula data; may share relevant processing techniques.
Oct 27, 2021
[RCC] The Horsehead nebula for the first time !
Hi, I'm 16yo I'm french and this week I took my first pictures with my skywatcher 200/800 in an exceptional sky (like bortle 1) ! I'm very happy it was amazing but I don't really know how to process this kind of nebula. here is the re...
Relevant; addresses dark nebula processing with similar Skywatcher equipment setup.
Jan 5, 2019
