dkamen avatar
Hi guys,
Yesterday I was not able to focus. There were relatively strong northern winds but nothing I haven't seen before, and the telescope was well protected (no shake at all).
I used the exact same equipment (178MM + VMC 110L) that I had used the night before yesterday, but things simply looked too fuzzy. When measuring with the Ekos Focus module, the best possible HFR was around 2.2 (usual value: 0.9 - 1.1) and when using a Bahtinov mask I could see the pattern having perfect symmetry except all spikes were fuzzy.
I thought the VMC was throwing a fit (perhaps it somehow became uncollimated) so I tried with my small 30/360 apo and the result was the same: the stars never stopped being fuzzy balls, at "sharpest" focus they were simply smaller fuzzy balls.
I also excluded the camera or the filter or the reducer having an issue by trying with another camera and all kinds of filters (or no filters) in front.
And I was able to focus closer than infinity, I picked a street lamp about 200m away and focusing was so sharp you could see the scratches on its pole.
So I am reasonably confident it wasn't my equipment.
My question is: is this a known thing? As far as I could tell the sky was very clear, stars were not twinkling, I could see quite a lot of asterisms with the naked eye and PHD on the small guiderscope was also recording fairly good SNR (in the 30s and 40s while 18-25 is more typical).  Also this morning I was able to see the moon in the Western horizon with quite a lot of detail, until about 11 am actually. But my imaging telescope(s) just couldn't deliver anything better than fuzzy balls or fuzzy Bahtinov diffraction patterns.
Any ideas?
Thanks,
D.
Chris Price avatar
Did you have any Dew on your optics that’ll make that happen every time.
Chris
dkamen avatar
Nope. It was a very dry night.
And I did check for dew (and dust).
You are right that dew would make that happen but it wasn't.
Tonight (right now in fact) I can focus. The only difference is the northern winds are not as strong.
David Redwine avatar
What exposure time were you using for focusing?  It might have just been bad seeing.
matthew.maclean avatar
Are you in a location subject to that recent Saharan dust storm by any chance?
dkamen avatar
My usual exposure for focusing is 1-2 seconds (depends on the brightness of the star in hand). For imaging it is 120-180 seconds. Both were fuzzy. But not shaky at all. It did look like serious dew except there wasn't any dew.
I am in Greece. Saharan duststorms are not very rare and are real showstoppers. I'd say at least two weeks per year in total. But they are brought by southern winds. Northern winds usually mean super clear skies.
I remember reading somewhere that seeing can be bad because of conditions in the upper atmosphere even though things seem pretty good to the naked eye. But I can't find the link.
PJ Mahany avatar
You are the victim of what I call really fast seeing. This is high altitude stuff.  Was the jet stream overhead?. I have see for instance the disc and rings of Saturn dissolve and enlarge to twice the diameter or worse. If you look at an out of focus  bright star outside focus you'll be able to see via a Scherin effect what's happening up there .  Beer is useful at this point. Don't forget to wave your hand in front of the objective to see a graphic example of heat currents.
PJM
All things about focusing a DSLR and Camera Lens...
So I'm currently shooting with a Nikon D810 and a Nikon 200-500mm f/5.6 at 500mm. I've found focusing to be the hardest part of the process so far. I've tried a bahtinov mask with limited success. I've used APT in conjunction with and...
Discusses focusing challenges with DSLR and camera lens equipment similar to author's issue.
Apr 13, 2022
Optimizing star shapes
Dear Masters of the Dark, while beeing a bit busy for the last two months (and will be until the end of may), I was able power my rig during the last few nights. I have to get rid of some things that bother me in my images. So I decided to optimize m...
Directly addresses star shape optimization, relevant to author's fuzzy focus and HFR problems.
Mar 4, 2022
TSMKOLLI Collimation
I recently received the new TSMKOLLI collimating tool for use with my Newtonian and RC telescopes. I’m fortunate to have had good results collimating both telescopes with just a laser and Cheshire. However, with the Newt getting into awkward position...
Collimation issues can cause fuzzy images; relevant to troubleshooting author's focus problem.
Apr 28, 2022
