Hi, I own the ZWO combo; ASIair Pro, 30F4 guidescope and 120MM Mini.
I use it to guide… wait for it… my Canon 6D MkII with 200mm lens. OK, so I have been waiting 6months for an SW Esprit 100 which it will be a better match for.
By and large, I am very happy with this kit.
30F4 guidescope and 1200MM Mini work well and reliability together and with the ASIAir Pro - as long as I remenber to plug the auto guider into the usb b socket in the ASIAir and not the usb c (where is corrupts the data from the 120MM Mini). My only gripe is that the auto guider is held in with only two screws 120deg apart - making the 120MM lie squint with respect to the finder - so I don't have perfect focus over the field. I am probably doing something wrong here.
The ASIAir control of the autoguider is really good, alth ought I am not convinced I am seeing the full chip on the ASIAir display. I suspect I will have to buy a tablet, as I am doing all this from my iPhone
More generally the ASIAir Pro is excellent, and I would never part with it. It has both improved and sped up my sessions tremendously. With my old eyes I was struggling to use a polar scope, but the ASIAir PA routine allows me to align to within 1arcmin in less than 5 mins with my EQ6R- Pro mount. The only thing is that I have to switch the connection to my mount off on the ASIAir Pro app and rotate the mount manually by the 60deg required. I wasn't able to get the ASIAir Pro to rotate the mount reliably by 60deg; sometimes it didn't rotate at all, sometime it wouldn't stop rotating. When it did rotate properly, it tend to lose contact with the camera - invalidating the PA. No biggie.
The plate solve routine with the ASIAir is amazing - although it doesn't work for me if there is heavy vignetting/cloud/obstructions in the field. But, then again, why should it?
My one issue with the ASIAIr Pro is that about 50% the goto action drives the Dec axis in wrong direction - as if it was on the other side of the meridian. I haven't ruled out operator error on my part yet - but I think I have ruled out most of the stupid things I could be doing. Again this is not a huge issue - I only have to move the telescope manually in one axis to get close to the right position which I can check with plate solve.
I don't find the Focus terribly useful on the ASIAir - I prefer instead to use Live View on my Canon. The ASIAir Focus routine seems to be quite noisy, but then again I could just be picking the wrong stars.
This all appears a bit critical of the ASIAir Pro. Its not meant to be, I couldn't now observe without it. It is just a little idiosyncratic at times. I haven't had too many network issues, the box is about 10m from a Google wifi point.
Wow…. as I finish this the house has had a decent shake from an earthquake - probably from the fault just off Milford Sound.
