Small but mighty tuning for the EQ6-R. Change the pulley!
PinguruRostokkoWim van BerloTom Marsalasebaromano
55 replies4.7k views
Pinguru avatar
Hey everyone,
I recently purchased the Skywatcher EQ6-R. It is the "latest" Version with the USB Interface.
To be clear: My worst guiding sessions with this mount are comparable to my best guiding sessions with my previous mount (Exos-2).
With the help of PHD2 Log Viewer and some curiosity, I have figured out two issues with the belt drive of the two axes.
1. The pulley/belt contact has some amount of inherent backlash (relevant for DEC)
2. The pulley/belt interaction creates a repeated deviation in tracking speed (relevant for RA)
Let me show you what I mean.
Point 1:
The backlash of the pulley can be seen in this little video I have made with my mount:
Video Link to Youtube
You can see that the pulley can move a little bit without the belt moving. The belt tension was already relatively high. This may be amplified by the fact that I usually lube rubber belts with a thin film of silicone oil to keep them smooth and reduce wear.
Point 2:
About every 10 seconds I did see a little spike in the RA guiding. With a longer guiding session this subjective finding became a hard fact. I have a major peak in my RA guiding with a very precise period of 10 seconds. The 10 second period is exactly the freqency of the belt teeth running in/out the pulley. In PHD2 Log Viewer you can analyze the guiding data to get an FFT of the frequency distributon:
The picture above is the data of the RAW RA movement. So no corrections of the guider applied.
The picture above shows the remaining error with the guiding active. The longer period errors can be managed by the guider. But the "fast" 10s period still comes through. The guiding is not fast enough to deal with this.
Analysis of the problem:
The pulley does not seem to fit the belt ideally. This is the main problem and a simple change of the pulley to a new one would most likely solve most of the problems mentioned above.
Doing my research I found, that the T2.5 belt design used in the EQ6-R is maybe not the best choice. The T2.5 profile can have more backlash than other more modern belt profiles. Apart from this, having just 12 teeth on the pulley means, that just about 5 teeth are working simultaniously. I decided to make a change to the whole belt system and replace it with the very available GT2 belt common in most 3D-printers. This belt profile is optimized for minimal backlash due to its circular teeth shape.
What I did:
I have calculated the drive I could fit into the small installation space of the EQ6-R. Turned out that the smaller pitch of 2 mm of the GT2 belt allows to fit a 15/60 teeth combination instead of the 12/48 of the stock T2.5 belt. This gives me about 6 teeth working simultaneously on the pulley. Not a lot more, but an improvement still.
I have ordered the 15/60 pulleys and the 178 mm (89 teeth) belt from Amazon and Ebay.
The 60 teeth pulley has two guideplates on the sides. They are too large in diameter to fit in the EQ6-R. They need to be stripped down to have an open pulley, just like the stock 48t pulley. To have everything working smooth and safe, I have chosen the 15t pulley and the belt in 6mm width and the 60t pulley in 10mm width. This ensures that the belt can never fall off the 60t pulley.
https://www.ebay.de/itm/283315656377?var=585025474753
https://www.ebay.de/itm/283302996132?var=585025245636
https://www.amazon.de/dp/B081DBPW21?psc=1&ref=ppx_yo2ov_dt_b_product_details
The gear is relatively cheap so I was not afraid to use some force getting rid of the guide plates:
This is all you need for the refit.
To change the pulleys you will have to open the electronics cover and loosen the motors from the inside to release the belt tension. This is well documented in other sources. I have not taken pictures of this.
Take out the old belt and remove the motor from the mount to take off the pulley. Loosen the grub screws and pull off the pulley. If you are unlucky, the pulley has some glue attached to it and will not easily slip off. I could pull mine off with a little patience, a droplet of oil and gentle force...
For the 48t pulley, you can open the little screw on the top side of the worm carrier. This gives you access to the two grub screw of the 48t pulley. You don't have to remove the whole worm carrier or change your worm play at all.
The 48t pulley can be glued on as well. Super annoying. On that pulley I have used the two threads in the stock pulley to push it off with two screws. Do this gently. The force is directed through the worm bearings and can easily damage them. I am not conccerned, because I want to replace them in the net weeks. As always, be gentle and patient.
Clean both shafts after you have removed the pulleys.
You can see the marks of the screws around the left shaft from my efford to take the pulley off.
EDIT: having the belt removed is the ideal time to check your fit of the worm gear. Then you can feel the play or friction without the belt influencing your perception!
Spin it all the way round with and without the clutch pressure. You will feel a difference in play between the different positions of the clutch. If the clutch is on the same side as the worm, the play is maximal. If the clutch is opposite from the worm the gears can be mashed together a bit more. Try to find the best of both. This ist the best time to do this :-)
In a future post I may address this topic with a special kind of new bearings (lower radial clearance). But this is a task for future-me.
Replace the pulleys with the new ones and the new belt and apply a good amount of belt tension. You might want to fasten the motor and drive it back and forth without seeing the belt changing tension visually depending on the direction. Close the PCB while doing this to avoid a short circuit.
The big 10mm 60t pulleys fit into the available space, but it is close. You have about 1 mm between the backside and the cover of the housing. In my mount I could make it fit relatively easily without making contact on the front or backside.
Of course you can machine away the front an back edges of the pulley to have a lot of room for aligning. But I don't have access to a lathe at the moment.
Result:
DEC-Axis: The backlash is gone. I don't have proper data to show this, but I can't feel, see or measure it anymore.
RA-Axis: After some hours of guiding I am pretty sure that this improvement was worth the time:
As above: One picture shows you the raw, uncorrected RA and the other gives you the RA with the active guiding. The scale is the same.
The belt period is now at 8 seconds, because of the higher number of teeth.
As you can see, the peak is gone.
I am very pleased with this result. I have expected to see at least some residual peak at 8 seconds.
Conclusion:
A nice little mod for <40€ and <2h of efford. The effect on RA guiding performance is noteable.
You can go all the way like me but I think just replacing the pulley with something like this should be a great first step to try:
https://de.aliexpress.com/item/32794928013.html?spm=a2g0o.productlist.main.5.78433e7a5Pgv3e&algo_pvid=7148bb8b-4230-471a-aacd-d90002aeb72e&algo_exp_id=7148bb8b-4230-471a-aacd-d90002aeb72e-2&pdp_npi=4%40dis%21EUR%2122.93%2119.48%21%21%2124.31%21%21%40211b88f016927950637633993e1dfe%2163980288919%21sea%21DE%214628680248%21&curPageLogUid=jRlaeypeTuqD
Please be so kind and let me know if your EQ6-R shows this FFT peak at 10 seconds as well.
And let me know if just replacing the pulley for a new 12t T2.5 does the same job as my full belt rebuild.
Best regards, Volker
EDIT: all FFT plots above are based on long guiding sessions with about 1.5 hours of continuous guiding + dithering (exclude settling). I am not interested in faking good guiding results with short analysis intervals. The exposure time during those sessions was 300s. The dither command was set to 7.5". The stability criteria was: <1" for 3s with 90s timeout (no timeout in analyzed sessions).
Christian Koll avatar
Volker,
I believe you have discovered some amazing findings here and sharing this with us in such a detailed manner cannot be praised enough!
Many of us use the EQ6-R - so thank you so much!
May I ask, what RMS values in arcseconds (RA and DEC, or combined) did you have before and after the modification?
I did a bearing replacement on my EQ6-R and with this I managed to bring down my guiding RMS (combined) from 0,3-0,6" to 0,2-0,4".
Maybe the trick was only to loosen up the RA and DEC end screws, which were tightened up way to hard.
Well done & CS!
Chris
Pinguru avatar
Hi Chris,
I have not focused my evaluation on the guiding RMS (for now).
At the moment the temperatures, the seeing and my available patch of the sky don't allow an apples to apples comparison.
Right now I just can image near to the equator and the most data prior to the mod was collected at high DEC-values.
The RA-RMS is directly influenced by the DEC coordinates of the target, so I skipped the RMS-part for my post.
I will post them once I have imaged unter comparable circumstances.
Loosening the main preload nuts for both axes a little bit was also something I did during the first days :-)
A regrease of the RA is also on my list. Maybe the final RMS comparison will include more than just the pulley mod.
Best Regards and Clear Skies!
Volker
Helpful Respectful
Joe Linington avatar
I need to plan a full hypertune.
Pinguru avatar
If you have an idea what could cause this other spike at about 95s period, please let me know:
It clearly happens 5 times during one worm rotation. So it can't be the concentricity of the motor pulley, this would be 4 insted of 5 times.
Having a damaged bearing at the worm shaft (brinelling) would give me an defect order of 4,4 times/rotation.
I am not sure about this one. I am struggeling to find a mechanical correlation to the system.
It doesn't really matter for the guiding. The 95s period is slow enough to be corrected as seen above. Still I am wondering what it could be.
Philip Bartlett avatar
Hi Pinguru,
Fabulous post!
I have an NEQ6 mount, a cousin of the EQ6-R with much of the same internal parts, and have upgraded it with the Rowan Belt Kit. After much testing, I also found that there was significant change in the worm meshing in the DEC axis when the clutch was released and moved to different positions. To adjust the meshing so that there was no play over the full 360 degrees, made the meshing too tight at at DEC=-90 degrees (I'm in the Southern hemisphere) and greatly increased the DEC backlash. Curious as to whether  the bearings were the problem, I decided to replace the three main bearings and the tapered bearing in the DEC axis using better quality SKF bearings. This seemed to significantly reduce the problem and I'm getting good meshing and backlash (about 100-150ms in Phd2) throughout the range of DEC movement. I certainly didn't do any systematic testing and can't be certain that it was the bearings, or some other problem that was remedied when I rebuild it after the bearing change. I look forward to your "future-me" investigation.
Philip.
Padraig Farrell avatar
I think have the same on a AZ-EQ 6 pro,
Of course, my guiding and PA wasn't that great that night anyway !
Very interesting post, thanks for sharing.
Bogdan Borz avatar
Thanks a lot for your excellent post! Very useful and nicely presented.
Bogdan
Pinguru avatar
one more thing:
If you plan to change the whole belt drive. Consider drilling two holes with threads in the large pulley.
This gives you two advantages:
1. If you are struggeling to get the pulley off again, use the threads to pull the pulley off like mentioned above
2. You can turn the pulley easily with your fingers if you have two screws installed so you can check the worm mashing easily
I have taken my pulleys out again to drill the two holes per pulley
Of course you need to take the two screws out again to reinstall the cover.
@Christian Koll : I think I don't have suitable data to compare the RMS results. I was taking a lot of exposures high in the sky with the EQ6-R prior to changing the belt, but I was taking mosaics. And my strategy is to take just 3 exposures per panel and then move on. This gives my even sky quality for the panels, but just very short guidelogs. I don't like to base a comparison on just 15 minutes of guiding. But a log of a recent testrun gave me the following, very promising results (51 minutes, DEC=0°, just west from meridian)
--> EDIT: I have found a guidelog from me imageing the M16 Eagle Nebula at -14° DEC prior to the mod. Not a perfect comparison, but better than nothing.
picture above: A guide log prior to the mod. Performance is overall good, but you can see the periodic and needle like character of the RA graph.
picture above: A guide log after the mod. Not perfectly compareable, but the super strong periodic error of the 10s (8s) period is down to the overall noise.
PPEC was not active in both of the sessions.
I want to work on the DEC performance, but this is a subject for another topic.
A. Chapron avatar
Hi.
I had the same problem with the Rowan kit for my heq5. A 13,6s period error.
Changing the pulley solved the problem
Wim van Berlo avatar
When I got my AZ-EQ6 some 5 years ago, I made the same observation. I increased the belt tension to get rid of that annoying 10 s period (at least, most of it). In normal guiding with >1 seconds guide exposures, that 10 s peak shows up as noise in the guide graph. You can only see it when using short guide exposures. That doesn't mean it's not there with longer exposures. It just means that you can't resolve it in the analysis. The 120 s peak, btw, is one full revolution of the motor pulley. But this can be guided out.
cs,
Wim
Well Written Helpful Insightful Concise Supportive
Pinguru avatar
Wim van Berlo:
...I increased the belt tension to get rid of that annoying 10 s period (at least, most of it)...
Hi Wim,
did you recognize an increase in belt wear with the higher tension? I have seen pictures of the EQ6-R with rubber flakes everywhere around the belt.
Volker
Markus Gorski avatar
Hello,
on my EQ6 R I was able to eliminate the belt play that can be seen in the youtube video by changing the position of the respective motor so that the tension of the belt sections on both sides of the drive sprocket was the same. Then the pull is the same on both sides.
Best regards!
Wim van Berlo:
Hi Wim,
Volker
There is some wear, and I have replaced the original belts with reinforced ones which I purchased from Belting online. I do have spare belts, just in case... I have also replaced the motor pulleys with better ones. The original pulleys had pressed on cover rings, that didn't impress me very much. The replacements are one piece pulleys, with the cover/guard ring being part of the body. I purchased these also from Belting online. Belts and pulleys are consumables on these mounts, and having spare belts is recommended.
cs,
Wim
Padraig Farrell:
*** yes, you need to tighten the belt. 10 s periodic error is impossible to guide out, unless maybe you use sub second exposures. Something which I wouldn't recommend, as you'll be chasing both seeing and noise.
cs,
Wim
Concise
Pinguru avatar
As mentioned above, the large 10 mm wide pulley fits in the mount but you don't have a lot of space
You can play around with a total of 1.5 mm of axial space.
Wim van Berlo:
Padraig Farrell:
cs,
Wim
Yes, just tension both belts , it’ll be interesting to see results,
will post as soon as clear skies
👍 Wim
Christian Bennich avatar
Very nice!!!!
Definitely something to look into. Thank you for sharing!
Tom Marsala avatar
Very interesting, indeed! I just ordered the mod. Thanks for sharing this information.  I've never noticed that much play as you showed in your video (or much at all) with my T2.5 system, but I am going to try this and see if I can get my RA to improve.  I am using polyurethane upgraded T2.5 belts already, but could not find any  GT2 belts that are poly ur.  Everything seems to be rubber or fiberglass.
I will report Total RMS updates as soon as I can get this done.  If others who are trying this can report any Total RMS improvement, let us know!
Abundant Clarity-Tom
Oscar H. avatar
A bit of an off-topic question, directed to the EQ6-R users here; I wont interfere with the topic in any other way:
if you could be a beginner without a mount again, would you still get the EQ6-R Pro, or an AM5, or something else?
I want to eventually sell my AVX mount (which I'm hating more and more) and get something much better; idk what's the best mount for the money though.
Tom Marsala avatar
ooo, loaded question!  If I had the money?  A Paramount or AP or 10-micron.  But on my budget, I would buy the EQ6-R again.  It does well for the price and is easily adjustable, easy to work on and upgradeable.  It handles my heavy rig very well.
The harmonic drives are too new for me to really vote on just yet.  From what I've read, they seem to have comparable guiding figures as the EQ6-R.  I really like the idea of strain-wave drives; they don't seem to be that much of an improvement, however.  They are lighter, for sure.
Can the EQ6-R be better?  Yeah, of course.  But, for what we paid, I think it is a great mount!
Wim van Berlo:
Hi Wim,
Volker
Warning!
a while ago the RA motor axle of my AZ-EQ6 snapped, which may have been due to material fatigue. To get rid of the 10 s periodic error of the mount, you can tighten the RA belt, but this will increase the strain on the RA drive. Last winter we've had quite a few cold nights, but also mild weather. The combination of the high belt tension and temperature cycles may have strained the RA motor axle to the point of breaking. The RA motor is easy to replace, so it wasn't much of an issue for me. But still, don't over tighten belts on your mount. Especially if your mount is exposed to large temperature fluctuations, a loose belt is probably better than a tight one.
cs,
Wim
Helpful Respectful Concise Engaging Supportive
IrishAstro4484 avatar
Hey everyone,
Point 1:
Point 2:
What I did:
Result:
Conclusion:
*** Love the rigorous analysis. I've always had significant declination backlash with my EQ6-R mount and never been been able to fix it. There is no obvious movement in the Dec axis when I tighten the clutches bbut the declination backlash becomes apparent when using the guiding assistant in PhD 2**
Tom Marsala avatar
I did this upgrade and i am happy to report that my rms has improved from 0.9-1.3 to 0.5-0.9.  to be clear, I also upgraded bearing and did a thorough regrease, but it feels tight and performs beautifully! Thanks again for posting this!
Tom
Coolhandjo avatar
A. Chapron:
Hi.
*** Hi, I think my HEq5 rowan belt mod could do with an upgrade also. Do you mind sharing where you obtained your pulley parts from?  ***
William Optics RedCat 71 focuser blues.
I was very fortunate and got my hands on a WO RedCat 71 from Teleskop Service about a week ago. But I am having second thoughts because of the focuser which is very tight, the tightest I have ever experienced on any "lens". Though I haven&#...
Focuser tuning may address tight focus ring issues on optical equipment.
Dec 19, 2021
PHD2 exposure times with multi star guiding
Hi folks, for a while now, the multi star guiding functionality in PHD2 is available. Currently, I am using version 2.6.10dev2. The guide scope is a SVBony 60mm/240mm guide scope with an Altair GPCam3 178M or a ZWO AI 120MM mini. All this is mounted ...
EQ6-R tuning may improve guiding performance with author's mount.
Oct 31, 2021
Star Adventurer GTi
https://teleskop-austria.at/StarAdvGtiSet#m Announced for May 2022! Looks very promising to me :-) It has all the features I would have seen on the original Star Adventurer back then… Both axes motorized and it comes with GoTo. Weight: 2.6 kg P...
EQ6-R tuning relevant to motorized mount optimization and performance.
Feb 10, 2022
Looking for advice on image processing
The following image was about 3 1/2 hrs of data on the Crescent nebula. I know the stars are bloated, it's noisy and the colours don't seem right, so just wondering what any of you would do if you saw this kind of result (apart from cry). Cle...
Guiding improvements directly address the 1.5 arc second guiding problem mentioned.
Dec 9, 2021
Limits of my star tracker
I wonder what people think the limit of an unguided star tracker is. I regularly take 60 second exposures with a 300mm lens and get a reasonable rate of frames without trails. I have recently tried to extend this to 2mins when using a narrowband filt...
Mount tuning improvements directly relevant to unguided tracking performance.
Sep 18, 2021
