Which dedicated solar scope for a beginner?
2 replies261 views
Rick Evans avatar
I know almost nothing about solar imaging.  I've ordered a DayStar Quark Chromosphere unit for use on my 80mm Esprit and120mm Esprit telescopes.  I'd use it with a standard UV/IR filter.
At the same time, I'd like to get a dedicated solar telescope that is double stacked for more contrast.  I am told that Lunt is a better bet than Coronado, although I don't know if this is true.  I think I could make do with a 40mm or 50mm scope but have been advised to think larger which means a lot more expense. Is there any advantage for an absolute beginner at solar to start with a solar scope larger than 50mm?  Is it necessary for decent images of the usual targets?
Rick
Eddie Bagwell avatar
Hi Rick,
Good decision to start getting into Solar imaging with the DayStar Quark. It's affordable and can produce some amazing images. I have been using mine since last summer and couldn't be happier with the results. After you learn to use the Quark and get your processing down, the Lunt would be a smart next step.
Message me if you have any questions as I would be happy to help.
Eddie
Well Written Respectful Concise Supportive
SemiPro avatar
You already have the Quark, so I would try that out and see how you like solar imaging before dumping any money into permanent scopes.
That being said, if you do want an actual solar scope you cannot go wrong with a Lunt. I would keep an eye out for used ones. I have a 50mm and it gets the job done, although I won't be winning any images of the day with it.  There is a total eclipse coming up so it might be hard to get you hands on one.
Lunt 40mm
Lunt 40mm can bé a good solar telescope? thanks.
Directly addresses beginner solar telescope selection and mentions specific solar imaging equipment.
Sep 29, 2021
Noob telescope aperture question
I am new to AP, but have a lot of photography experience and I think that helped me get a good kit to start with, but understanding scopes is infinitely more confusing than lenses. I have an askar 71f as my starter scope. I am very pleased with it an...
Discusses telescope aperture selection, relevant to author's scope size deliberation.
Jan 8, 2025
